What would you like in a snorkel design?
Wow... I just finished reading every post in the thread.. It's been a long haul. Would have been about a third as long if folks would take the time to read before asking the same questions over and over...
That said, RR, nice work.
The install is pretty straight forward and I've already had the sawzall & cutoff wheel on my 2011, so not much of a big deal to cut a little behind-the-scene sheet metal.
The pre-filter option is pretty much perfect for what I need. I recently installed a Banks CAI and I can't lie...I worry about ingesting water during my daily commutes.
The only worry I have is the length of metal pipe and the clamps needed to assemble it being so low. If I am following the setup details, that stretch of pipe is easily accessible from below correct? So it might be easy enough to inspect the pipe and clamps periodically.
I'd love to see some close-up images of the low intake setup.. just to see the cosmetic details. Not sure that the stack is useful for how I use my JK.
can someone explain to me how the low intake is better then stock. I mean, i dont want the tall stalk, but like the idea of being able to splash a little bit more and go a little deeper in the water. so the lower one would work for me, right? Is it actully higher then stock inlet?
Originally Posted by knight1000
can someone explain to me how the low intake is better then stock. I mean, i dont want the tall stalk, but like the idea of being able to splash a little bit more and forge a little deeper. so the lower one would work for me, right? Is it actully higher then stock inlet?
Yes it is a little higher, also you have that "U" curve before water can get to the actual air box, so that gives u a little insurance and last, if you dip the nose you have more space and depth to get to the air intake, you can dip the hole hood before having water in... I think is still better than stock to have the lower intake.
so i was browsing through the SEMA thread and found this....
http://project-jk.com/gallery2/main...._itemId=268312
looks like the pricetag is gonna be at $399.99....can we get some confirmation on this and when it will be released to the public???
OK... working with my mold vendor and we are having to rework a few parts to allow them to be removed from the molds with less effort (very important for large scale production). These are the small things you just cannot take account for until you are this close to production.
Here are a few images of the early prototype installed onto our 2011 JK (so please excuse the quality of the image and the rapid prototype part). As you can see the main body of the intake is mounted inside the front fender. This requires the removal of the front fender, but the flare can come off with the fender (at the same time). The side cowl will need to be removed (spot welds drilled out) and a section of the front fender will need to be removed. From there it is rather simple. The lower section of the air box is replaced and an aluminum air tube is routed between the engine and the shock tower. The stock air filter and intake tube to the engine are retained.
AEV is a known quantity, and simple (if not blunt) design.
I really would have liked to get this clean RR design, rather than the AEV. The Rugged Ridge design is sooooo much better than Volant (Volant engineers should be banished for that mess).
The JKL has been out for 5 years now. That's half of the predicted model life-cycle. If you guys want to be successful in business, you've got to jump in earlier in the model life-cycle. Whatever the JKL replacement turns out to be (I'll start the rumors now: next model Wrangler is code named: JFD for Jeep Fiat Diesel) you gotta be first or second to market.
The sign said "msrp 399.99." Maybe there could be a preorder discount for us so we can show them off to the world and bring in more business for RR. I still love the design and I've been given the go ahead when it comes out. I guess the question is, when can we start placing orders??
