Dealer fixed my soft top leak....
Old Apr 30, 2009 | 07:18 PM
  #31
keno4x4's Avatar
Will try this this weekend. Thanks for the info
Old May 2, 2009 | 03:59 PM
  #32
PA RUBICON's Avatar
well, did the fix and the passenger side still leaked. but not as bad without the washer fix. so readjusted my striker in just a bit. had a lot of rain since. no more leak. finally a dry JK. the door handle leak is so common you would think they would have fixed this for 09.
Old May 2, 2009 | 04:56 PM
  #33
interceptor_1972's Avatar
Well, it rained last night, and sadly, the washer fix didn't work. I still had leaks inside, although it did seem like it wasn't quite as much as usual - on both the driver and passenger sides. However, I do notice that the foam weatherproof around the edge of the header area is basically flattened; will try the weatherstripping fix next and see if that works. Where exactly did you adjust the striker at? Any pics? Open to suggestions
Old May 2, 2009 | 09:37 PM
  #34
katsumotology's Avatar
Default Silly putty
A long time ago, someone put a fix using silly putty. I tried this. I used silly putty and put electric tape where door surround meets that the gasket. This fix works for me for the fix of the leak over the door handles.
Old May 3, 2009 | 02:35 AM
  #35
PA RUBICON's Avatar
oddly my drivers side never leaked a drop. on the passenger side i adjusted the striker on the pillar. the silver one. two torx bolts. i never touched the hinges. just got some tape to outline the origional position of the striker. then, thru trial and error moved it in a small amount at a time, till the leak totally stopped. if you go to far in, the door will be very hard to close. very stubborn leak! only would leak when sitting and raining.
on a side note, found the fore mentioned silly putty fix.
https://www.jk-forum.com/forums/show...ht=silly+puddy
Old May 3, 2009 | 02:42 AM
  #36
RedneckJeep's Avatar
Cool. Glad you got some satisfaction from your dealer. Mine is about as useless as tits on a borehawg.
Old May 3, 2009 | 07:16 AM
  #37
BaltChief's Avatar
Funny thing about these leaks. What works for some does not for others Are the tolerances that different on each Jeep? Seems like bad engineering at its best.
Old May 3, 2009 | 07:40 AM
  #38
PA RUBICON's Avatar
BINGO! thats got to be it.
Old May 3, 2009 | 09:33 AM
  #39
That's what I'm noticing as well. When I bought my Sahara at the dealership I work at, we also had an X, same year, same color. One of our customers ended up buying the X, and he has had absolutely NO leaks. And if you looked at the top on the X vs. the top on the Sahara, I'd have sworn that the X would be most likely to leak
Old May 15, 2009 | 08:35 PM
  #40
joearod524's Avatar
I did mine today then parked it in the rain...no leaks!!!
I know some people had asked for pics, so I took a few along the way.
Washers ($.92 from Lowes for 4):
Placement:
Done:
