Installing Softtop on 2013 JK
Hi Everyone,
I've taken the hardtop off my 2dr JK and put the softtop on. I'm just not sure if I've put the arms in the right position as there seems to be a considerable gap at the back. I'm unable to pull the back all the way (must be short at least 3-4 inches). Can someone confirm I've indeed correctly put the 2 arms in the right position or what else may be the problem?
All of the videos out there seem to be only applicable for the 4 door model.
Thanks in advance!
Thanks in advance!
I went out and looked at mine and it's the same as yours. What does the part look like that is not going down?
Also, you need to have the rear hooked before you attach the front clips at visors
Basically, the back flap will not reach the body. Its about 3 - 4 inches short. When I do the back first, the front is too short to reach the clips.
Maybe the material is just too tight...that is a lot of stretching it needs to give. Guess I will have to wait for a hot sunny day for the material to stretch enough.
