Cb mounting locations with sPOD
Old May 19, 2015 | 05:23 PM
tarpon4me's Avatar
JK-Forum Ambassador
Default Cb mounting locations with sPOD
My current set up is a cobra 75, which has done ok but I'm looking for something with more features and power. I've been eyeballing the Bearcat 880 and 980. Anyhow, I also have a sPOD so a traditional over head mount won't work. Not trying to side mount it or hide it in the console. I hope for some type of factory look, maybe even flush mount. My jeep is a 2014 manual with the large touch screen radio. I've searched the web for hours and not found anything. Help!!!!!!!
Old May 19, 2015 | 05:51 PM
wolfgang239's Avatar
Can't confirm but I found this post suggesting it might work with the Arizona Rocky Road mount.
As far as radios with more power or features, the 980 and 880 do have more features than a 75. They do not have much more power and are not easily modified to produce any perceptible distance increase.
Old May 20, 2015 | 02:40 AM
Reepo's Avatar
This was my solution. It's worked out great so far. And I have the sPod mounted on the footman's loop above the rear view mirror.
https://www.jk-forum.com/forums/jk-w...0/#post3926616
Old May 20, 2015 | 04:44 AM
tarpon4me's Avatar
JK-Forum Ambassador
It's funny you mention that. I continued to search after this post and read that the Cobra 29LX was a much better choice because the "tweaks" with the old tried and true 29 will still work with this one. I've actually decided the Cobra was the better choice as a result. Does it sound like i'm on track?
Old May 20, 2015 | 09:27 AM
Angry_Fisherman's Avatar
Here's a couple photos of my 2 meter radio install. Its somewhat out of view and not in the way of anyones feat or legs. i couldn't hear the radio so well, so i got that little Motorola speaker it fits perfect held in place with double stick tape. I wedged the speaker wire between the plastic to plug it in the radio.
Pull your glove box out and youll see the crossbar that i mounted the radio bracket to. Perfect fit.
Im thinking i might get a Cobra 29 and mount it right next to the 2 meter radio if it will fit.
ID:	611583   Click image for larger version
Old May 20, 2015 | 05:29 PM
Yes much better choice. I'd order it from Bell's with a standard tune up.
Don't overlook your antenna system, even the nicest radio won't get out with a crappy setup.
Old May 27, 2015 | 08:06 PM
JCDriller's Avatar
I'm thinking about taking the factory sound bar, removing the light and glassing the CB as high as I can into the sound bar facing forward. While it would be backwards I can see the channel in the mirror and or turn to look while stopped. Once everything is set I don't typically change anything anyway. Speaker would be close and it would be out of the way. I'd simply wire in new a new light for the overhead.
Old May 27, 2015 | 08:44 PM
kmrtnsn's Avatar
We went this route.
Quadratec Exclusive JK-APT2011 - 12 Volt Power Adapter for 99-15 Jeep® Wrangler TJ, JK , TJ Unlimited & Wrangler Unlimited JK - Quadratec
Quadratec Exclusive JK-CBM11 - Quick Disconnect CB Radio Mount for 07-15 Jeep® Wrangler & Wrangler Unlimited JK with Uniden Pro 510XL Radios - Quadratec
Old May 28, 2015 | 05:00 PM
MD GP's Avatar
I agree with kmrtnsn. This mount looks almost factory, holds the radio well away from legs, allows the speaker to have its voice, and the base plate can accept a mount for either small or full sized radios. Two thumb screws allow easy removal of the radio when you don't need it, or easy swapping between a CB and a Ham radio.
Old Jun 3, 2015 | 09:25 PM
fitzb's Avatar
Used KC hi lights bracket to my RockHard cage mounted in front of spod
