Full sized CB
Old Oct 16, 2008 | 10:55 AM
  #31
tuffy2's Avatar
Sponsoring Manufacturer
Originally Posted by jsmoriss
I had to remove the retaining nut on the coax connector, then push it half-way inside the CB. I screwed on a 90 deg. fitting on the connector, and to keep the connector tight, I added a large zip-tie around the connector on the inside. This keeps the 90 deg. fitting flush with the back of the CB.
js.
Tuffy made the main compartment about 1/2" longer so it wouldn't be such a tight fit with the coax coming out the back. It still depends on the specific radio hopefully the modification you mentioned won't be necessary for everyone.
Old Oct 16, 2008 | 10:57 AM
  #32
hyatt147's Avatar
good to know because im looking at that setup and i have a cobra 29 as well
Old Oct 16, 2008 | 01:17 PM
  #33
JK-Fire's Avatar
I like that setup alot.
Old Oct 16, 2008 | 01:25 PM
  #34
JKGuy's Avatar
Default RE: Tuffy
Maybe Tuffy should make an overhead that doesn't have a locking box and is just a sheet of metal so that we can bolt up whatever radio we want?
Old Oct 16, 2008 | 01:58 PM
  #35
gtin's Avatar
dont have a pic of mine but i just screwed it to the top of the dash like the others over the radio
Old Oct 16, 2008 | 06:08 PM
  #36
mainejeeper's Avatar
what happens to the spaker in those CB's mounted inside the tuffy console? Can you still hear them, or do you need to hook up an external speaker?
Old Oct 16, 2008 | 07:17 PM
  #37
Choppus's Avatar
They have holes in the bottom and you are supposed to still be able to hear them. Not sure how good it works though
Old Oct 17, 2008 | 03:17 AM
  #38
RubiConz's Avatar
Here's mine:
Old Oct 17, 2008 | 03:23 AM
  #39
jsmoriss's Avatar
The Tuffy box just adds to the 'canned' sound of the CBs internal speaker. An external speaker is definitely a must.
js.
Old Oct 17, 2008 | 05:09 PM
  #40
djdingo's Avatar
Originally Posted by jeepnoob
Here's mine:
Are you my twin?
I also have a 2-door flame red Jeep, not Ruby though.
I have that EXACT same model of CB mounted in the EXACT same spot!
Is it a full moon tonight?
Oh, those wondering, when I mounted mine, like the one above, I just used the screws that came with it. Used 3 actually, one in middle and one on each side. No worries about it falling down, it's solid as a rock, never had it move at all. I used the walkthrough on project-jk.com, here's the link...
http://project-jk.com/jeep-jk-write-...nd-model-1001z
