My Cobra 75 CB and antenna install
I just paid about $200 for the Cobra 75, four foot Wilson tunable antenna, wire etc...
Sweet, I am going to look at it tonight. The guy even said he'd help me install it. I told him i didn't need help I have friends that know what they are doing lol.
Thanks Guys. I'm subscribed. Might have some questions although it's been pretty well covered here.
I went and picked up the Cobra 75. I'm a noob with a CB so be gentle
It was only 5 months old and in working order. It came with the connecting box (power supply?), cb unit 4' whip antennae but didn't have a cox or antennae mount. I plan on making the antennae mount that's no problem. My question is what coax should I buy (I'll need about 10') and should I buy a kit with connectors? What connector for the antennae mount is good and should I buy a quick disconnect?
Any help will be appreciated.
Would this work? hXXp://radioworld.ca/amateur-accessories-mounts-cable-kits-cr-5m-p-933.html
. It was only 5 months old and in working order. It came with the connecting box (power supply?), cb unit 4' whip antennae but didn't have a cox or antennae mount. I plan on making the antennae mount that's no problem. My question is what coax should I buy (I'll need about 10') and should I buy a kit with connectors? What connector for the antennae mount is good and should I buy a quick disconnect?
I skipped the QD because I want to leave it on all the time and don't want to worry about it getting ripped off..
As far as the coax.. most vendors sell the 18 foot coax with the ends on already. That will give you enough to go from under the dash to anywhere on the rear of the Jeep with some left over. It's the easy option.
You need to check the mate on the antenna or mount.. for instance, some Firestik mounts work best with the FireStik coax with the FireRing..
I used this mount..
It required a specific coax cable end.
What you linked to looks like an extension..
Something like this is probably the most popular along with the FireRing cable.
Not sure if I answered your question..
I used this mount..
