So where have you been mounting the CB's?
Old Sep 11, 2012 | 09:11 AM
  #261
TURTLECON's Avatar
Originally Posted by Trail_blaster
In my previous JK I had a Tuffy Overhead Security Console. I liked the fact it took my full sized Cobra 148 CB. Besides being center mounted up high, I liked the fact that I didn't have to worry about someone breaking into my Jeep to steal my radio.
I also have the Tuffy center console. I installed my Yaesu FT-859 in it for the same security reasons. I had considered putting the radios elsewhere, but I didn't want my passengers to hit them with their legs or have them high enough to attract unwanted attention. I also didn't want to have to take them out after weekend wheeling or trips.
Why would you have to take them out after trips?
I like the idea of the Tuffy overhead console, but I don't like that it takes up so much of the "topless space" above. It definitely looks cool but feels like it takes away from the topless function. Plus they're pretty pricey and with the model Cobra I have, the security door won't close & lock because of the CB's knobs. I will probably end up relocating the CB into the center floor console anyways. Being mounted right now off the footmans loop it still shakes a bit on semi-rough road... I can't imagine how much it will shake on the trail. Any ideas?
Old Sep 15, 2012 | 06:00 AM
  #262
The Dark Knight's Avatar
It will shake, mine does. Mine is huge and heavy. The thing is, it won't fall off no matter how much it shakes. There is only so much it can shake. I have been trying to come up with a way to stabilize it even more to reduce the shake but all in all most of us only use the CB on the freeway and the trail. Just take it down when not in use.
ID:	365898   Click image for larger version
Old Sep 15, 2012 | 07:33 AM
  #263
conifers4's Avatar
Originally Posted by Rule18
I went with a Uniden 520xl and a Cooltech Gatemount kit with a 4' Firestik. I did the insulated clamp-on-the-footman loop installation although I turned the left corner bracket facing inward which allowed me to center the radio mounting bracket. In the JKU, the 18' of coax included in the kit doesn't reach when running it up through the A pillar. Those with four doors, how are you extending the coax? Thanks!
From the tailgate route the coax thru the rollbar padding.....believe it or not you will end up with extra.
Old Sep 15, 2012 | 07:53 AM
  #264
Jeek.OlllllllO's Avatar
I ran mine though the bottom but my cb is under the glove compartment but its a 18" and it just made it i was trying to do it though the roll bar but it would not pass the dam speakers! I have a hard top so i just ran it where all the cables are at
Old Sep 15, 2012 | 12:59 PM
  #265
Daltonabner's Avatar
Hey guys just got my cb installed just have a quick question. If you have extra coax cable what should you do with it or does it even matter in terms of hurting your antenna range.
Old Sep 15, 2012 | 01:03 PM
  #266
TURTLECON's Avatar
I believe you're supposed to "stuff it" not "coil" it in a spot where the excess will fit. I think I read that coiling it will interfere with reception.
Old Sep 17, 2012 | 04:42 PM
  #267
lolpetewtf's Avatar
I have got to thank Rooster and the rest of you for the Footman loop idea. Worked great on my CB install yesterday on my 2012 with hardtop. Here are a few pics:
I drilled an offset hole so it slightly angles toward me.
http://www.flickr.com/photos/pjtocci/7990355737/
Relocated the 2A fuse:
http://www.flickr.com/photos/pjtocci/7990364288/
http://www.flickr.com/photos/pjtocci/7990355519/
Super low SWR on all channels
http://www.flickr.com/photos/pjtocci/7990184070/
I used an Arizona Rocky Road antenna mount. Worked out ok. They supply 6 fender washers for the base but I used two .5" locking washers - seemed to work better.
http://www.flickr.com/photos/pjtocci/7990364672/
I use a 4' Firestik II. Did not even need to tune it.
http://www.flickr.com/photos/pjtocci/7994473044/
There is a quick overview. Here is my album about the install on my Flickr account:
Cobra 29LX - a set on Flickr
Old Sep 18, 2012 | 01:56 AM
  #268
Kojack's Avatar
Any other place to put the fuze?
Pain to change the fuze if anything happens.
Old Sep 18, 2012 | 02:26 AM
  #269
Patman's Avatar
Is the antenna on a spring? Seems like it will hit a lot of branches, drive through signs/overhangs etc. The firestik II ain't that flexible...
Old Sep 18, 2012 | 02:51 AM
  #270
Kojack's Avatar
I was thinking the same thing. blue whip looks awesome tho. Patman, are you the same patman on KLR sites?
