So where have you been mounting the CB's?
Old Sep 18, 2012 | 04:16 AM
  #271
lolpetewtf's Avatar
Originally Posted by Kojack
Any other place to put the fuze?
Pain to change the fuze if anything happens.
You can leave it in the original location but then it will be a clusterfuk behind the CB. If the fuse blows just take the freedom panel off. Simple.
Originally Posted by Patman
Is the antenna on a spring? Seems like it will hit a lot of branches, drive through signs/overhangs etc. The firestik II ain't that flexible...
No spring. I have a quick disconnect. Where I go wheeling it is mainly wide open. Jeep sees far more highway time. If I need a spring in the future I'll throw one on.
Old Sep 18, 2012 | 04:31 AM
  #272
Rule18's Avatar
Originally Posted by conifers4
From the tailgate route the coax thru the rollbar padding.....believe it or not you will end up with extra.
Good call, I can't believe I didn't think of that. Thanks!
Old Sep 18, 2012 | 07:31 AM
  #273
lolpetewtf's Avatar
Yup, lots left over. Much easier than running through carpet, although that is not very hard either.
Old Sep 19, 2012 | 09:50 AM
  #274
Rule18's Avatar
Well now that I've run the coax THAT way, everything worked out fine... Now I just need to get rid of my ignition noise. I'm surprised that I've got any since I ran + and - directly to the battery. The ANL switch gets rid of most of it from my speaker, but I'm not sure if it's heard by others when I transmit. I'll eventually get out on the trail or road and ask, but does anyone know for sure?
Old Sep 25, 2012 | 05:41 AM
  #275
lolpetewtf's Avatar
What CB are you using? I wired direct to the battery, even without NB/ANL I get no noise. Does your CB include NB?
Old Sep 27, 2012 | 10:37 AM
  #276
Jersey_Devil's Avatar
Originally Posted by gldwings1
Another option if you like is the tuffy overhead console and there is a dash hoop with a center plate that runs back to the roll bar made by I believe High Rock. It's available from 4 wheel parts.
Keep the shiny side up,
Chuck
Tuffy makes one for $235 from quadratec that's what I wanna get! I'm gonna go check out this high rock one on 4 wheel parts now
Old Oct 10, 2012 | 09:09 AM
  #277
jaleporq's Avatar
Originally Posted by Wile E
Cobra 75 WX ST with UltraMount CB Antenna System
What did you use for the piece where the mic plugs into the power source that goes through your dash?
Old Oct 22, 2012 | 05:39 AM
  #278
PhotoWrangler's Avatar
Originally Posted by TCJK11
I found a good spot!
I have been debating on what kind of CB I wanted, and what kind of mounting I was going to do - but, I think you just made up my mind for me.
I always wondered what that little pointless plastic cover was for...
Old Oct 22, 2012 | 06:28 AM
  #279
Cowboy5150's Avatar
On mine it a 12v plug.
Old Oct 22, 2012 | 07:16 AM
  #280
BrainTrix's Avatar
Took some time and a saw to the dash this weekend came up with this
ID:	381049   Click image for larger version
