So where have you been mounting the CB's?
Old Sep 9, 2013 | 07:55 AM
  #331
Jersey_Devil's Avatar
I put mine right above the rear view mirror....just screwed it in, no special mounts....just the supplied cobra mount
Old Sep 9, 2013 | 08:03 AM
  #332
AaronJK's Avatar
I was thinking about doing that. I like the look. I put mine on the side of the center console. I offset the mounting hole and used a spacer to make it fit. I'm also in the process out bedlining the interior.
Sent using my SuperSmartThinky Phone
Old Sep 10, 2013 | 03:57 PM
  #333
firecapt's Avatar
Here's mine tucked away in the console.
Old Sep 21, 2013 | 05:57 AM
  #334
Brittcale's Avatar
Here's my version of an overhead mount.
ID:	499155   Click image for larger version
Old Sep 25, 2013 | 10:27 PM
  #335
deepjeep13's Avatar
Originally Posted by Titanium Dad
This is where I mounted mine.
Im really interested to know how you mounted your cb. I put mine up and my freedom tops arent sitting right now
Old Sep 26, 2013 | 01:48 AM
  #336
soberbyker's Avatar
First I bought a complete set from Search results for: 'cobra 75' which included:
Cobra 75 WX ST CB radio
3' or 4' Firestik FS or Wilson Flex CB antenna
Mounting options:
3-Way Vertical Surface & Mirror Kit
Jeep Wrangler Hood Kit (1997+ Jeep Wranglers)
Universal Hood & Channel Kit
Bandi Mount (FireRing and stud for FJ Cruisers; $19.95 upgrade)
Teraflex Tail Light Kit (TJ, CJ & YJ models, 1987-2006; $19.95 upgrade)
Teraflex JK Tire CB Mount (antenna stud and 18' of coax; $19.95 upgrade)
Compact external speaker
Standard SWR meter and jumper cable
Very impressed with the Teraflex mount, very heavy duty and appears to have been powder coated.
When this was first installed I was getting horrible SWR readings, over 5 and sometimes as high as 10. I'm guessing the tail gate isn't grounded. I went back and sanded the paint off where the mount bolts connect to the tire rack, I also ran a ground wire from the tailgate to the body floor, again sanding where ever there was direct contact needed. After all that my readings were 1.1 on channel 1 and about 1.4 on channel 40, great readings as far as I am concerned. With everything good to go I went back and painted any exposed bare metal, including the bolt heads.
I also bought a Versa Mount 2 from
Cool Tech LLC. JK VersaMount 2 for the mic mount, another heavy duty product.
For power I used a cigarette type lighter adapter in the center console, which is powered even when the Jeep is off.
One last item I included was a Hustler QD2, heavy duty quick disconnect for the antenna I picked up at a local CB shop.
Here's some photo's of the finished install.
Shot of the Hustler QD2 on the tire mount:
Ran the antenna coax through a punch out hole in the tailgate to the mount. On the inside ran the coax and the ground wire inside the pull off panel on the gate with the third light wire.
Here's where I grounded the wire from the tailgate to the body.
Ran the coax along the passenger side wall, tucking it in where I could.
Under the floor mat up to the rear of the center console.
Coax into the center console on the drivers side, the power plug, the power/antenna/speaker switch box and the SWR meter (left inline) all in the center console, the CB/mic cable goes out the passenger side up to the Versa mount. (I taped the ends of the power plug to keep from accidental shorting out and blowing a fuse, ask me why I know to do that :redface-new
The console has some cutouts perfect for the running of the cables.
Old Sep 26, 2013 | 01:49 AM
  #337
soberbyker's Avatar
Last few shots from my CB install ...
The Versa Mount 2
The external speaker in front of the gear selector, stays in place too.
Old Sep 26, 2013 | 07:15 PM
  #338
darkknight1999's Avatar
Originally Posted by xj2jk
I did the in dash install.
Love it!
I'll be doing something similar.
Do you find one interfering with the other at all?
Old Sep 30, 2013 | 06:50 PM
  #339
wmphoto's Avatar
Originally Posted by jkfisher84
How dafuq? Does that effect the navigation thingy?
Hasn't affected the Navigation radio at all
Old Nov 1, 2013 | 05:52 AM
  #340
etl330's Avatar
anyone know if i'll be able to fit a uniden bearcat 880 above the rearview on a 2013 with the bigger automatic dimming mirror?
