Old Feb 14, 2013 | 05:21 PM
  #2301
Sahara_Maverick's Avatar
Originally Posted by Cool Danish
I finally got my homemade custom 2012 dual battery tray back from the powder coater and started installing it in the Jeep.
I also added a little sheet metal to the bracket that holds the wiring harnesses directly under the battery tray (is has exposed wires right next to the catalytic converter and can only get brittle over time with that kind of heat). See first picture for this bracket.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=420440"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=420441"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=420442"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=420443"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=420444"/>
Next is making all the electrical connections (Winch/ARB dual compressor/Main/Auxillary fused links).
The fuse holders in the second picture are (from left to right). 1. ARB Dual Compressor, 2. Main supply, 3. Blue Sea systems Automatic Charging Relay, 4. Auxillary supply.
The high current fuse for the Winch can be seen in fourth picture.
I'll post more pictures with the final result (hopefully the Jeep will start after this major surgery ).
Awesome job! How's it working? I've been thinking about converting mine to a dual battery setup also and yours look very good.
Old Feb 14, 2013 | 05:37 PM
  #2302
NFRs2000NYC's Avatar
Originally Posted by skibovr6
I like the ACE rails but I have a 13 month old son and a wife that like the step bars.
Both the ace and the smittybilts are the same height as the OEM sahara (mine is a sahara too) but are wider, making entry even easier.
Here are mine...you can't see the width on the photo, but they are probably 2" wider than the OEM steps.
Old Feb 14, 2013 | 05:46 PM
  #2303
Cool Danish's Avatar
Thanks!
I will be working on completing all the wiring this long weekend.. I will let you guys know how it turns out.
I am curious to see how well the Blue Sea Automatic Charging Relay works out.. It does have many advantages over the Cole Hersee relay. (Higher continues current = 500A and it does not use power in either switched state.. where the Cole Hersee does use some power when in the connected state, since it's an actual relay).
Looking at your profile it looks like you have a pre-2012, so you will have many off-the-shelf dual battery trays to pick from.. So you would only have to source all the electrical parts (assuming you want to do it yourself).
Don't get me wrong, it was fun to make my own tray. But it does put your Jeep out of commission as you are fabricating. Since my Jeep is not my DD, it was not really a problem for me.
Old Feb 14, 2013 | 06:19 PM
  #2304
rattler_thesnake's Avatar
Originally Posted by emiles1987
Here's one from last fall
Emiles1987 did you make those or did you find them somewhere.....
Old Feb 14, 2013 | 06:33 PM
  #2305
skibovr6's Avatar
If you are asking about the limb risers, check out offroad elements. Amazing customer service and awesome products
Old Feb 14, 2013 | 06:57 PM
  #2306
Dlampe's Avatar
Originally Posted by NMBruce
easy or hard to build? any welding? where would I buy the parts?
Sorry, I missed a few days on the thread and missed your question. There was a lot of welding. I ordered about all of the stuff from McMaster-Carr. It was a little time consuming but it works great.
Old Feb 14, 2013 | 07:03 PM
  #2307
Thanks I will check that out
Old Feb 14, 2013 | 07:09 PM
  #2308
Dlampe's Avatar
I ordered mine yesterday and they were fantastic. Helped me get them in time for a weekend adventure at no extra charge! You can't go wrong with these guys!
Old Feb 15, 2013 | 01:30 AM
  #2309
Mark Doiron's Avatar
Ditto on Offroad Elements. I have them on mine, but fabricated a short bracket so that I could install them to the MRBP overhead rack extension instead of the supplied brackets mounted into the windshield frame. Contacted Eric at Offroad Elements and asked if they could make a custom length so I could remove my bracket, and he said no problem and will get back with me on price. Superb product--every component is top-notch in quality.
Name:	Limb Risers, Feb 13.jpg
Old Feb 17, 2013 | 05:15 AM
  #2310
Dlampe's Avatar
Default Gobi Ladder Question
I have a gobi ladder question. I have been searching for a good shot of how the ladder attaches to the rack at the bottom. It seems like it would flex enough to touch the body over the tail light. I was hoping someone could show me a picture of how this works or discribe it to me. I'm sure it doesn't scratch the paint but I want to see how they do it.
Thanks.
