How much weight do you feel a trailer could weigh without having to add airbag helpers in the back or a auxiliary trans cooler? Do you think a 2,800 lb fully loaded popup or travel trailer would cause any issues? I'm realizing that for me to do the traveling I want to do with a full family is going to have to have a much bigger tow vehicle.
Regarding the lockers, stock will be fine unless you're doing something REALLY intense which 90% don't ever do...
I hope this helps.
I am sure you will do fine. I forgot to mention that if you don't have a Rubi or some type of suspension lift, you may not have room to crawl under the Jeep to do the harness install, but I am sure you would have noticed that by now. Jack stands will work if needed. I am also a research junkie, but I didn't discover any factory harnesses that would work for a brake controller on a JK. (Practically every other vehicle under the sun but not the JK for some reason). All the research I did pointed to having to tap a wire from the brake switch. It would be great if you didn't have to do that.
It's not exactly a factory harness. I still have to splice into the brake switch wire according to the video. Funny thing is my wife's 2014 came with a trailer brake kit connection. I'm not sure if it would fit my 2011 yet, she's not willing to give it up yet lol.
I'll post pics of the install and try and do a write up because i haven't seen one on here yet about it.
http://www.jeepforum.com/forum/f27/m.../index101.html
http://tventuring.com/trailerforum/thread-64.html
I was saying don't upgrade just for lockers. Upgrade for the superior motor and transmission. If you keep your older rig, ARBs are better since you can lock up in any mode, not just 4wd low, as well as front and rear separately. There are many situations where I've found this lockup freedom useful. 4:10 and 35s with the new transmission is fine. I'd bet by the time you are done, you'd be better off dollar wise with a 2014 Rubi vs. a fully built 2010 sport, especially when you consider you get little resale value on mods.
[SUP][/SUP]Measure where your wheels will sit, including back spacing. Call abctrailerparts, they will quickly build whatever you want for cheap. Make sure u order with correct bolt pattern. Are u adding e-brakes? Now is the time to decide. With stockers, you may indeed need spacers for the hubs to clear, but u can also drill out wheel centers for clearance (if you don't mind seeing the grease caps) or do with modified flat caps.
if you get the axle you need, it should be ordered by hub face to hub face, so if you are going to use spacer, you need to add that measurement in. Personally, I would get spacers, have them lathe or cut to fit the hub, that way should you need a wheel down the road, any similar Jeep wheel would fit. I did that and my wheels are 7 AEV Pintels (5 JK, 2 Trailer) I found used and a 5 spoke JK wheel for the spare.
You could have them add the face/bracket for brakes and decided later if you are going to have e-brakes or not. At this time I am not putting brakes on my trailer, but my goal is to keep my total weight around 1000-1400lbs or less.
Here is the write up on the MOPAR 7 pin trailer connector I installed today. Put a Tekonsha P3 brake controller too. I just have to switch the connector to the bottom connector on the tail light instead of the top, so the left side lights work, just ran out of time. It really went better than I expected. I put the controller below the turn signal stalk, it's close, but has enough clearance to make it convenient and not in the way too.
https://www.jk-forum.com/forums/jk-w...nector-302810/
Everything working great! Hooked the Mopar harness to the bottom connector on the tail light and left and right sides work perfect.
Here is the brake controller I put it. A Tekonsha P3. Fits well and is the best on the market with a digital accelerometer instead of a pendulum. Got it installed in a great place where it isn't in the way, I can see it and I can activate the manual brakes if need be.
