Design of tracks is very important for the strength to be able to hold the weight of the vehicle, maxtrax ^-^-^ shape is a good design. I am not saying other designs are not good, just maxtrax is a good design.
Aluminum is a pretty soft metal. Many plastics are stronger than aluminum for equivalent size/design. Aluminum also has a short elastic range so it not an ideal material for a bridge.
There are Aluminum alloys which are strong and durable. Just see how Aluminum alloys hold up under stress in airliners.
I have Aluminum skid plates, which were moved from my previous Jeep to the current one, and have proven themselves for years.
In very low temperature, plastic becomes brittle. In hot weather it 'dries' faster and eventually looses its properties.
The plastic ones are typically shorter, which often makes them useless as a bridge.
A well designed Aluminum sand ladder easily supports a heavily loaded JKU and doesn't bend like plastic.
I've used and seen them used many times, including under heavier 4x4s than Jeeps.
They also provide better grip when wet, than plastic does.
Like other products, some are very good, some are "less than very good".
The best design for Aluminum sand ladder/bridge (in fact, any sand ladder/bridge), include down-sloped edges.
Here's a short comparison. Notice how the Aluminum with slopped edges does vs the rest --
Those of you who have watched my videos have probably seen on several occasions where we changed our plans due to flash flood concerns. I know that park rangers tend to be on the very conservative side when advising visitors, so it's easy to become complacent with the advice you receive. But their advice is only one piece of the puzzle. Pay attention to weather radio, Internet reports (if you have data access), satellite radio weather broadcasts--whatever you can gather. And make prudent decisions. It can be dangerous out there--be careful!
adventure journal ? 4 Canyoneers Dead, 3 Missing in Zion Flood
Utah Town of Hildale, Ravaged by Floods, is Home to Secretive FLDS Sect - NBC News
Fitted to the flash shoe is a Zune H4N. The H4N has two built-in mics and two optional mics inputs for four channel recording. I just use the two built-ins. The H4N can record the audio to an SD card, but I connect it to the camera mic audio input with a special patch cable (a typical 3.5 mil audio cable will fit, but you need one with an L-pad built into it to provide proper impedance matching). Therefore I don't usually have to mess with audio synching during video editing.
Fitted to the back of the camera is a Zacuto Pro 2.5X eye loupe. For best, handheld video shooting, you definitely need to press the camera against your face to help stabilize it. So the eye loupe offers steadiness, and also makes it easy to see the LCD image.
Drove some of the Oklahoma Adventure Trail a couple days ago. We followed about an eighth of the route from near Stillwater to north of Pond Creek. Here are a few photos. The rest are in my public FB album here ...
https://www.facebook.com/media/set/?...1&l=2fae647a22
We ended up with three bridges on the 02-05-14 published route being out, and one road so overgrown that we turned around (suspecting its bridge must also be out). However, detours around those areas were easily found and only 2-3 miles before we were back on the OAT. It was actually one area in particular where the trail follows a creek--we suspect that flooding in the spring may have caused the damage we saw. Should have a video up before too long!
The OAT route and current reports about it are available here ...
http://advrider.com/index.php?thread...-trail.836706/
