Grill Mod
I was wondering.....has anyone tried this version.....looks pretty good.....sounds like all the materials needed are included....except the glue.......
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
after it's all donw)
I used a full piece and I like the looks, I cant believe how easy it is to get the grill off. If I want to change styles it will be soo easy. Thanks to all of you that posted here.
I picked the piece of galvanized screen up at our local Ace Hardware store. This is stiff and it doesn't really look like it but it won't block the air flow hardly any. The piece was an end piece off a roll. The whole thing, zip ties and tie blocks and gorrila glue and screen cost about $20.00. I really am glad I did it.
Just finished mine up using the black plastic gutter guard from the local big box home center. It's an easy mod, and I never would have thought of it with JK-Forums! I figure it will last about 2 years before needing refreshment.
Gutter Guard: $4 (Roofing Aisle)
30 Zip ties: 6$ (Electrical Aisle)
30 Zip-Tie Holders $6 (Electrical Aisle)
1 Tube Loctite Epoxy $4 (Paint Aisle)
And I still have material left over, though I went little wild with the Epoxy, so it's all gone!
I completed this mod using the 7 piece and zip tie and block method. I orriginally used 3 on each side and 1 at the bottom of each opening. After 1 highway streach, 1/2 of the blocks had come loose. I recleaned the surface, replaced the blocks, and added 2 more to each side of the opening. The blocks came off again.........any suggestions?
