Grill Mod
Old Jun 5, 2010 | 12:35 PM
  #701
toe_knee's Avatar
Default mmmmm.....I wonder
I was wondering.....has anyone tried this version.....looks pretty good.....sounds like all the materials needed are included....except the glue.......
http://www.google.com/imgres?imgurl=...26tbs%3Disch:1
Old Jun 6, 2010 | 07:41 PM
  #702
hx15537's Avatar
For $40 I would just make it myself. For that style of grate, you can make it for way cheaper yourself. If you want something a little different than the diamond grid you can order sheets of perforated aluminum for a little more.
Old Jun 7, 2010 | 05:03 PM
  #703
08GreenRubi's Avatar
x2 that is why this thread exists Cheap mod that looks GREAT!!!
Old Jun 9, 2010 | 07:26 AM
  #704
Arrogantbastard's Avatar
The mesh looks very tight. I think it would cause a restriction of air. Plus, this section is all about trying to do it your own way, even if it can be purchased somewhere else. It's 1/2 the fun (the other 1/2 is admiring your work with a after it's all donw)
Old Jun 11, 2010 | 06:23 PM
  #705
Highlander's Avatar
Default I did mine today
I used a full piece and I like the looks, I cant believe how easy it is to get the grill off. If I want to change styles it will be soo easy. Thanks to all of you that posted here.
Old Jun 11, 2010 | 11:19 PM
  #706
hx15537's Avatar
Not bad, what type of material did you use?
Old Jun 12, 2010 | 06:51 AM
  #707
Highlander's Avatar
I picked the piece of galvanized screen up at our local Ace Hardware store. This is stiff and it doesn't really look like it but it won't block the air flow hardly any. The piece was an end piece off a roll. The whole thing, zip ties and tie blocks and gorrila glue and screen cost about $20.00. I really am glad I did it.
Old Jun 29, 2010 | 07:11 PM
  #708
ls6tt's Avatar
does anybody know what size diamond opening the OP is using? or the ones that the purple11haze guy was giving away? i dont want to go too small
Old Jul 1, 2010 | 06:36 AM
  #709
flyingfleet2000's Avatar
Just finished mine up using the black plastic gutter guard from the local big box home center. It's an easy mod, and I never would have thought of it with JK-Forums! I figure it will last about 2 years before needing refreshment.
Gutter Guard: $4 (Roofing Aisle)
30 Zip ties: 6$ (Electrical Aisle)
30 Zip-Tie Holders $6 (Electrical Aisle)
1 Tube Loctite Epoxy $4 (Paint Aisle)
And I still have material left over, though I went little wild with the Epoxy, so it's all gone!
Old Jul 3, 2010 | 05:26 PM
  #710
blackedout's Avatar
Default I cant get the zip-tie blocks to stay on
I completed this mod using the 7 piece and zip tie and block method. I orriginally used 3 on each side and 1 at the bottom of each opening. After 1 highway streach, 1/2 of the blocks had come loose. I recleaned the surface, replaced the blocks, and added 2 more to each side of the opening. The blocks came off again.........any suggestions?
