Grill Mod
Old Dec 12, 2009 | 05:42 PM
  #601
GDK's Avatar
GDK
Did mine last weekend and it turned out great. Thanks to all that have posted their different methods of getting this done. Can't believe how easy it was to do and it looks great. JK newbie
Old Dec 19, 2009 | 06:40 PM
  #602
cwargo's Avatar
Finally got around to uploading my photos...
Old Dec 20, 2009 | 05:51 AM
  #603
Detonatorunlimited's Avatar
I'm interested in knowing what cwargo used as well......very nice job.
Old Dec 20, 2009 | 07:12 AM
  #604
cwargo's Avatar
Went with the plastic gutter guard from Lowes - thought about using metal but liked the way the plastic followed the bend in the grill and didn't want to worry about paint chipping on it. Also liked the price
cut seven strips and used the zip tie blocks from Home Depot - they fit right in between with no cutting. Peeled the sticky tape off and used Gorilla glue to hold them in place - couple thousand miles and no problems so far.
Overall an easy mod that looks cool
Old Dec 22, 2009 | 12:17 PM
  #605
JKBANDIT55's Avatar
Ill be doing this here in few weeks. Looks awsome!!
Old Jan 7, 2010 | 09:49 PM
  #606
ajchiz's Avatar
Originally Posted by BlueBruin
I found using a paint can opener worked well to remove the plastic "screws". For those who are wondering, here is what the "screws" look like:
I found a piece of aluminum sheet at Lowes for $25. It was in the nuts&bolts isle by the small amount of raw steel they carry. I figured it was worth a try since it was quite a bit cheaper than ordering from McMaster Carr's like a lot of people do, plus you don't have to pay shipping.
I chose this clover leaf pattern. They had a few different options, but I thought this looked good and will let enough air through.
I used cardboard to make a template. Mine "hangs" on the top of the radiator frame where the grill attaches. Basically, it follows the same shape and size as the back of the grill. Here is my template.
Test fitting
You don't really need to attach the sheet in any way, it will be held behind the grill with the pressure of the grill pushing on it. However, I noticed during my test fit that the sheet tended to bow and create a gap at the bottom of the grill slots. So, I used another popular method to attach the sheet, which is using zip ties. First you get the sticky backs and attach them to back of the grill. I used gorilla glue to attach them since the sticky backing never holds. Here is what the grill looks like. You can see my zip ties holding the grill at the bottom.
Here is the finished product! You can't quite see what it will look like because I have my bumper off for my next mod...
Old Jan 21, 2010 | 08:25 PM
  #607
AnthemAVM's Avatar
Anyone sell a kit for this mod?
Old Jan 22, 2010 | 03:11 AM
  #608
starfire65's Avatar
They sell 'em. I think they call them "Grille Inserts."
They're expensive. That's why I did mine with the rain gutter stuff. A roll costs $3.99 at Ace, and you only use a fraction of the roll.
And it keeps the leaves out of that area in front of the radiator just as good as the $100 kind.
Old Jan 22, 2010 | 04:50 AM
  #609
cwargo's Avatar
I agree - no need to spend money on the $100+ version. If you go the gutter guard route, you only need a couple of bucks for the roll of gutter guard, a couple for the zip ties and zip tie blocks and a bottle of glue. Cheap mod but the results look great
Old Jan 23, 2010 | 10:20 AM
  #610
earnsdorff's Avatar
I'm headed to Lowe's for the gutter guard, bases, ties and glue!
I am still not certain about 1 thing:
Is it necessary to remove the adhesive back from the bases?
Or do you just place the glue on the adhesive back?
