Grill Mod
Old Jul 3, 2010 | 07:22 PM
  #711
ntropy's Avatar
Originally Posted by blackedout
I completed this mod using the 7 piece and zip tie and block method. I orriginally used 3 on each side and 1 at the bottom of each opening. After 1 highway streach, 1/2 of the blocks had come loose. I recleaned the surface, replaced the blocks, and added 2 more to each side of the opening. The blocks came off again.........any suggestions?
Are you relying on the little adhesive pads that the blocks come with, or did you soak and peel those off first and then super-glue the plastic backs of the blocks to the inside of the grill? Most folks that have had success with this mod have soaked the backing off the blocks either in water or goo-gone; the stick'em on those isn't gonna hold.
Old Jul 3, 2010 | 10:07 PM
  #712
hx15537's Avatar
I soaked the tabs in alcohol so that the adhesive pads slid right off. Let them dry and then Gorilla Glue 'em on there.
I would also recommend taking a little bit of sand paper and roughing up the spot that you glue them before you clean it. That will give the glue more surface area to bond with.
Mine has been holding strong for a long time. I used perforated aluminum which will cause a lot more air restriction that a screen, so if it's holding for me it should hold for whatever you use.
Old Jul 4, 2010 | 04:53 AM
  #713
blackedout's Avatar
I tried using the 2 sided that was on them. I think that I will redo w epoxy JB Weld
Old Jul 4, 2010 | 04:55 AM
  #714
blackedout's Avatar
Thanks for the tip. looks like I will be redoing it soon
Old Jul 5, 2010 | 10:38 AM
  #715
Kiawahgolf's Avatar
Default Grille Before & After..
Thanks to everyone for their tips on the Grill Installation! Couldn't have been a cheaper, easier way to upgrade the front-end.
https://www.jk-forum.com/forums/albu...chmentid=75400
https://www.jk-forum.com/forums/albu...chmentid=75398
https://www.jk-forum.com/forums/albu...chmentid=75401
Old Jul 5, 2010 | 12:22 PM
  #716
sn00wman's Avatar
Default sweet
I happen to have some expanded metal hanging in my garage right now that might be done by the end of the week....thanks for the good idea
Old Jul 7, 2010 | 07:53 PM
  #717
Dallas's Avatar
Default Added to the List
This is going on my list of to do's as well, great job
Old Jul 7, 2010 | 08:53 PM
  #718
jay-nyc's Avatar
this is one of the best mod for the price
Old Jul 8, 2010 | 12:40 PM
  #719
wrangler07's Avatar
I have this one:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=290451179029
Old Jul 10, 2010 | 06:41 AM
  #720
BlackoutJK's Avatar
Default Paint Issues
I dig this mod. I even found the metal and materials with ease. Maybe someone can help me out with paint issues. The paint is a flat black, Rustoleum brand. When I painted the metal it looked perfect. As soon as I went to place it in, it seemed dinged up already without having really taking any abuse. The metal was already shining through the paint. I put about three good coats on the metal. What am I missing? Should I prime it first? The metal was bare to begin with. Need guidance.
