Marker light mod
Old Aug 7, 2009 | 02:38 AM
  #121
MikekiM's Avatar
Read thru the posts....
Done in under ten minutes a side and that was being really anal with it since you can see the connectors from the side..Works perfect! For those that asked but didn't get a response the short piece of black wire that is left over, that used to go to the side marker... I taped it and tucked it back into the plastic wire loom out of side and danger.
Old Aug 7, 2009 | 04:01 PM
  #122
YingYang's Avatar
Great, worked like a charm. Wonderful mod. Thanks.
Old Sep 12, 2009 | 08:19 AM
  #123
Sounds like a great, easy, cheap mod. Cant wait to get home and start working off the list of stuff I want to do to the Jeep.
Old Sep 12, 2009 | 10:01 PM
  #124
SMP_70's Avatar
Last week I had someone almost pull out in front of me and as I passed they yelled, "Use your @&#%*! blinker!" Well I WAS using it, but I'm sure they were focused on the fender marker lens that doesn't flash. Well it does now!!!
Just did this mod this evening... took me a bit longer than most guys have noted, but I soldered all my connections and tucked the wires back into the plastic looms. Shoulda come from the factory like this.
Old Sep 14, 2009 | 11:27 AM
  #125
BIGCAT Texas's Avatar
Originally Posted by tuber
An important consideration when doing this mod - apparently the blue scotch locks used for this mod are not waterproof, which can lead to the wires they are connecting to become corrode. It has been recommended to me that using a "hydralink" style butt connector to join the wires instead is a much better approach. One source for this type of connector: ht tp:// store.anchormarina.com/anchor/details.php?ITEM=3309203
I've picked some up, and I'm replacing the scotch locks with them tomorrow. I think everything should tuck nicely back into the looming better with these anyway!
It will be interesting to see the condition of the wires after I remove the 3M quick connects - hopefully no moisture has gotten in there yet - I did this mod end of last October
You can always use liquid electrical tape to completely seal the entire junction....it really seals it completely - like a rubber coated seal - if you have't used that stuff you need to start.....We use it on all of our marine toys.
Old Sep 16, 2009 | 09:55 AM
  #126
Monty-'s Avatar
just finished mine. easy mod to do. really shoulda come this way from the factory.
Old Sep 17, 2009 | 04:21 PM
  #127
igtrdn's Avatar
After all the money I have dropped into my 2007 Sahara... this is the best $1.00 I have spent yet (connectors). Tested the lights without connecting the bumber and front parking lights, did not work. But once I got everything back together and hooked up it all worked fine!
Awesome mod!
Old Sep 18, 2009 | 12:36 PM
  #128
rinkishJK's Avatar
i did this mod last night. works perfectly!! super easy. BUT...
my question is has anybody else had there horn honk when unlocking????? mine is turned off but for some reason last night i hit unlock and i got a horn chirp. very odd. only happened once. thought it might be related to the mod.
Old Sep 20, 2009 | 04:26 PM
  #129
absrio's Avatar
I also just did this mod on my 2010. I get to drive it to work tonight so I can see how nicely it does at night. First mod with less than 70 miles on the JK. Took me about 25 minutes including figuring out where to cut the wire, taping the old end and tucking it in, taping the blue wire connector, and adding 1/2 wire loom over the connector and covering the old wire loom to the front light.
Great mod!!!
Old Sep 20, 2009 | 04:44 PM
  #130
DoubleG's Avatar
I am also a member of the flare turn turn signal mod group as of today
