Marker light mod
Old Nov 13, 2009 | 06:14 AM
  #141
rinkishJK's Avatar
i didnt use plastic tabs. i soldiered mine.
Old Nov 14, 2009 | 11:39 AM
  #142
Default Help!
Well I did as instructed and now I have no front driver's side blinker! I spliced the black side marker wire with the outer most white/green striped wire from the blinker and it just stays solid. I wired it back as original and now the front blinker remains solid and the rear is blinking fast. I swapped the front bulbs out and they check out ok. So what did I screw up...? One catch, my side marker is a LED with two wires (yellow and white) coming out of it. It works fine just doesn't blink.
Old Nov 14, 2009 | 01:01 PM
  #143
BullandTerrier's Avatar
It wont work with LEDs b/c LEDs only work in one direction. I know it sucks. I had to put my original bulbs back in for this mod. It was worth it though b/c people see me merging on the freeway.
I wonder if they make better bulbs that aren't led.
Old Nov 14, 2009 | 01:11 PM
  #144
The rear blinks fast because it's telling you that you have a bulb out. The front and rear bulbs are double filament so maybe you burned out one of the filaments in the blinker OR you have a bad connection.
Old Nov 14, 2009 | 05:24 PM
  #145
Thanks for the reply. I kinda thought that may be the reason (being an LED light and all). I checked the bulb and it works fine (swapped it out with the passenger side one). So now the driver's side lights are screwed up and the passenger side works fine. So I am guessing once you mess with the wires it won't go back to the original. I'm puzzled.
Old Nov 14, 2009 | 05:46 PM
  #146
sman's Avatar
Done this today, great mod!
Old Nov 14, 2009 | 10:18 PM
  #147
I have no idea. Make sure your connection is good and there are no exposed wires that will cause a short.
Old Nov 15, 2009 | 06:59 AM
  #148
Thanks again. Everything is "buttoned up" solid so I don't know. I am going to hook the original marker lights up and see if this corrects it. Word to the wise, if you replace your marker lamps with a LED, the blinker mod won't work (and it appears to screw up the front blinker in the process). If someone knows why this is or how to correct the problem, please chime in. Thx.
Old Nov 15, 2009 | 05:20 PM
  #149
Dewayne's Avatar
I used LED's and it works fine,the only thing I did do was solder the ground wire inside the light because I mounted the lights to plastic.
Old Nov 15, 2009 | 09:57 PM
  #150
Hmmm. Well I tried connecting my LED wires to just about every wire with no success. I'm guessing you connected the LED to the same wires mentioned previously. I figured mine would work because the relay would control the flashing part, not the light itself. If you don't mind me asking, what light are you using...?
