Marker light mod
I just completed this mod yesterday, and offer up a slightly different write up that served the same purpose.
Instead of adding another 8" length of wire to the severed side marker. I followed the black (ground) wire from the fender side marker up thru it's wire loom until it met the grill turn signal loom (the white with stripe). These two looms meet about an inch from the edge of the inside of the fender edge, adjacent to the headlights. With the grill removed there's plenty of space to cut and splice the black marker wire to the white stripped grill signal, and enough room to wrap a weather seal around the scotch lock splice.
Great recommendation for an excellent modification.
So all I need to do is cut the black from the (fender flare light) and tap it into the to white wire that isn't at the center at the front amber lamp.
What becomes the ground for the "fender light"
