Marker light mod
Old Nov 21, 2010 | 01:27 PM
  #241
TheDoubleD's Avatar
Default Blew my bulbs
Did the mod with the battery connected. Blew my bulbs. Hate it when that happens.
Old Nov 21, 2010 | 03:09 PM
  #242
erpeden's Avatar
Great free Mod
Old Nov 21, 2010 | 04:40 PM
  #243
Jhen's Avatar
Quick and easy Thanks
Old Nov 23, 2010 | 10:32 AM
  #244
dstock's Avatar
Originally Posted by cablecoffey
I just completed this mod yesterday, and offer up a slightly different write up that served the same purpose.
Instead of adding another 8" length of wire to the severed side marker. I followed the black (ground) wire from the fender side marker up thru it's wire loom until it met the grill turn signal loom (the white with stripe). These two looms meet about an inch from the edge of the inside of the fender edge, adjacent to the headlights. With the grill removed there's plenty of space to cut and splice the black marker wire to the white stripped grill signal, and enough room to wrap a weather seal around the scotch lock splice.
Great recommendation for an excellent modification.
Did the same thing without grille removal using a pois-tap connector. Took about 15 minutes total. Simply awesome.
Old Dec 22, 2010 | 09:17 PM
  #245
matt852's Avatar
So all I need to do is cut the black from the (fender flare light) and tap it into the to white wire that isn't at the center at the front amber lamp.
What becomes the ground for the "fender light"
Old Dec 26, 2010 | 06:31 PM
  #246
stanmpd's Avatar
That's about it. Did mine almost a year ago with no problems so far. It really does help.
Old Dec 27, 2010 | 09:32 PM
  #247
matt852's Avatar
So what acts as the ground for the fender flare light?
Old Dec 28, 2010 | 12:06 AM
  #248
Vic Hammer's Avatar
Worked perfect, thanks to the OP.
Old Dec 28, 2010 | 01:09 PM
  #249
BlkMtnJK's Avatar
just did this mod easy as pie and it works which is a plus for me. i usually need 2 or 3 tries to get it to work.
Old Jan 2, 2011 | 02:40 PM
  #250
Arebee's Avatar
Thumbs up
I did this today in about 15 minutes. Piece of cake!
THANKS!
