Marker light mod
Old Mar 21, 2008 | 08:03 PM
  #41
crjjeepster's Avatar
Just did mine...thanks..love this place..maybe 5 mins
Old Mar 22, 2008 | 05:20 PM
  #42
whpony96's Avatar
Originally Posted by seal20
Okay, as mentioned later in this thread, all you do is snip the black wirh coming off the side marker and tap it into the outmost white/brown wire that leads to the blinker. Ya, exactly....it should have come from the factory this way.
Check out the pic....it's worth a thousand words on how I got in there and did it. It's really simple and probably even easier since I had the grille off.
I tried this on my 08 and it did not work! I used the black wire from the marker light and mated it with the white \tan wire in the front plug.. Now they don't light as marker lights or a flashers now.
One thing I did notice is the picture posted does NOT show the Black wire cut from the marker but the white\green wire that is cut!
Please explain...
Old Mar 22, 2008 | 11:29 PM
  #43
seal20's Avatar
Ya the picture is wrong. It should have worked....double check your work and then check back it.
Old Apr 23, 2008 | 04:20 PM
  #44
VINdecent's Avatar
Just completed this tonight and it works fine on my 2008, Used a Blue Tap right before the connector at the blinker and ran a new wire up to the black wire from the side marker, snipped the black wire and used a barrel connector to my new wire. After it was all taped up you cant even tell, most of the wire and connector is hidden in the loom.
Old Apr 26, 2008 | 09:01 PM
  #45
whpony96's Avatar
OK I figured it out it is my LEDs They will only pass voltage in one direction. If I place a regular light bulb in the socket it works fine. I like my leds better they draw less voltage and will never burn out.
Old Apr 29, 2008 | 05:46 PM
  #46
BLKRUBI's Avatar
Shit, I should have read this earlier. I just tried mine and it didn't work and I couldn't figure out why, Now I see it's because of my GenRight LEDs. That blows. I was trying to make them and my front LED's marker/ turn signals since I don't have front markers now. So it ONLY works with normal bulbs then? Any ideas for LED's? Anyone?
Old Apr 30, 2008 | 03:37 AM
  #47
Ok I tried this last weekend. cut the black wire on the side marker, tapped into the outer most white wire on the blinker, NO GO. so I reconnected the black wire and then t-tapped into the white wire just blinked real fast. Now I am back to stock till I figure this out.
Old May 1, 2008 | 01:21 PM
  #48
BLKRUBI's Avatar
Made mine work with my GenRight LED's I'm trying to find a way to finalize it though.
Old May 1, 2008 | 02:13 PM
  #49
jeeper 43's Avatar
Default It works!
I remarked yesterday that it's a shame the marker light dosen't indicate direction also and today I find this solution. I printed the picture and followed the directions written and in 30 minutes my marker lights now worked as a side view directional signal. Thanks to all who contributed.
Old May 14, 2008 | 10:10 AM
  #50
Default marker mod didn't work
Tried this also, but didn't work. Did y'all cut the black wire at the side marker or futher back near the front signal and tap it onto the white wire of the signal light.??
