Stubby front bumper without plastic cover
Old May 29, 2012 | 11:47 AM
  #111
CRNA's Avatar
anyone have pictures of this mod done to the rear bumper?
Old Jul 14, 2012 | 11:13 AM
  #112
aerospacediver's Avatar
Default My Setup
Thanks for all the idea with this project. I kinda of took several ideas and combined them together and got a pretty nice end product. I took the factory bumper, removed the cans, found some aftermarket halogen fog lights and added a 12,500 lbs winch. I used the Body Armor winch plate mounting bracket ($50) and the harbor freight mounting plate ($40) and the fog lights are also from harbor freight ($18).
https://www.dropbox.com/sh/p3xncpyz36ub5fs/xzqoGLvR1y
Old Jul 14, 2012 | 02:00 PM
  #113
HighTide's Avatar
Looks good guys, simple and effective!
I added a peice of trex decking, cut to shape, to finish it up.
Old Jul 18, 2012 | 07:56 AM
  #114
enzo319's Avatar
U have a pic of the bumper with the trex decking? not sure what that is
Old Jul 22, 2012 | 05:41 PM
  #115
codenameerik's Avatar
Default First post/mod
Did my bumper mod this weekend. Fun build and turned out pretty well for drinking most of the time! Thanks for the build ideas everyone. Really helped give me some visions!
Name:	Stubby front bumper.jpg
Old Jul 23, 2012 | 05:46 AM
  #116
enzo319's Avatar
Good stuff man. Beer always helps
Old Sep 27, 2012 | 10:01 AM
  #117
Dnm1012's Avatar
Originally Posted by Dale36
Hello All,
I used the stock fog lights and sprayed them with a single coat of tail light blackout spray. The lights are housed in 4 inch black pvc pipe which does limit the ability to adjust them some. I removed the tabs from the black light housing so they would fit in the pvc. The pvc is then screwed/bolted to the bumper with brackets. The light housing is screwed to the pvs from the outside to hold them in place. Cut a couple notches in the PVC so they extended under that plastic thing a little (top view picture).
Those are PureJeep shackle mounts, Smittybilt schackles and Daystar schackle isolators.
I angled the ends of the bumper to match the angles of the grill - thought it would look better that way.
Did the standard bedliner spraying.
Sorry for the crap write-up. I got into it and lacked the abilty to take pictures during the build.
Thank you to the others for their posts. I pulled ideas from others.
Dale
I would like to copy ur fog light design can you tell me how you secured the gutter guard to the bumper and then the fog lights to it? Or maybe provide some close up pics from the front and the back of the fog lights?
Old Oct 3, 2012 | 03:46 PM
  #118
Jerkbait's Avatar
Here's mine. Finished it this afternoon
ID:	373965   Click image for larger version
ID:	373966   Click image for larger version
Old Oct 5, 2012 | 08:48 AM
  #119
MagnumD69's Avatar
Looks cool... however I'd be very, very leery about pulling anything with those D-Rings. The factory tow hooks are designed to pull in line with the frame and use the frame as the load path. There's not much supporting the bumper ends besides bent sheet metal. The metal would most likely fail at the worst time. Just watching out for you, buddy!
Old Oct 6, 2012 | 05:27 AM
  #120
bjay's Avatar
x2... any load on those D rings is going to bend the sheet metal and might even rip off which could be dangerous
