Under-Floor Storage
Old Nov 13, 2012 | 10:10 AM
  #171
scholes_76's Avatar
I Like this mod alot, has anyone done a version that is not carpeted and a little more water tight? I am usually good with my rain cover when the top is off, but sometimes that rain sneaks up on me and the jeep interior gets a bath
Old Nov 17, 2012 | 09:15 AM
  #172
NAlbertaJK's Avatar
subscribed
Old Nov 27, 2012 | 02:15 PM
  #173
absolutalchemy's Avatar
Since I have a 2 door and limited room I was thinking that instead of a flip up drawer style, I may benefit more from a pull out extension of sorts that makes the "sleepable" area longer. I realize that that would entail keeping the rear tailgate and/or glass open. Maybe some kind of tarp like ARB that come down from my rear rack to keep it bug free. Anyone done anything like that? If not I'll try to make it this winter.
Old Dec 3, 2012 | 04:47 PM
  #174
Extremehabit's Avatar
I'm looking to do the same. Remove the back seats and then make a flat bed area for more storage, reduced weight and if need be, sleeping in the Jeep. Has anyone done this? Anyone know what the rear seats weigh?
Old Dec 24, 2012 | 05:50 AM
  #175
I posted this to another part of the forum, but since I was following this thread figured I'd share my build too:
In preparation for an extended trip out to the Colorado area (and would be MOAB, except for that dogs aren't allowed, but I digress...), I've been in the process of planning and assembling an overland build.
With overland features in mind, an essential feature was to have more water carrying capacity, minimally altering GVWR and also making a more functional storage space. In the end, I also wanted the option to sleep in the jeep, for two, plus dog if need be. Not likely to be the primary sleeping arrangement, but it could be convenient and easy enough to do.
Attached are some photos of my build:
rear seat removed, brackets for FrontRunner 10 gallon footwell tank
brackets now w/ extensions to back for platform
platform in place, with optional to extend to rear seats for more headroom if sleeping
platform demonstrated near flush with back cargo area
option to flip up to access 10 gallon footwell tank in event it needs to be removed, drained, or tilted
For purpose of sleeping quarters, under carpet I placed a layer of thin insulation with has an aluminum feature to help reflect heat since the floor of the jeep could get awfully cold in cold weather and/or wind.
By removing the rear seat I estimate I easily removed ~50 lbs. Using a bathroom scale the seats weighed 80 lbs, but that seems a bit high. The platform I built weighs about ~30 lbs, water storage unit is about ~8 lbs and then 10 gallons of water is roughly ~80 lbs, so not a bad option for gaining 10 gallons of water capacity.
Old Dec 24, 2012 | 08:16 PM
  #176
Dano646's Avatar
Check out this thread. This cargo storage box worked well in the 2 door. It was tight sleeping but easier than setting up a tent.
https://www.jk-forum.com/forums/jk-s...atform-241985/
Old Dec 26, 2012 | 05:41 AM
  #177
wrangler unl145's Avatar
This is on my to do list!
Old Dec 26, 2012 | 06:48 AM
  #178
emt_micah's Avatar
So what is the strongest/lightest material go build a platform with? OSB? Plywood? Plastic lumber?
Old Dec 31, 2012 | 05:03 AM
  #179
HannibleMP's Avatar
On my list of things to do
Old Dec 31, 2012 | 09:46 AM
  #180
Cool Danish's Avatar
Plywood is going to be the strongest, lightest and easiest to work with (cutting/gluing/screws). OSB is pretty strong also and cheaper than plywood, but it will not stand up to moisture as well and is harder to glue/screw together.
