OK bs
You COULD ask for a million dollars - or a couple
Have fun and a great trip
Yes it does... Did you get the carrier installed on the hinges??? That was one of the biggest pain in the butt because you need someone else to hold the carrier while you run the bolt down with the shims and washers and what nots in a sequence
What controls the alignment? The 4 bolts on the gate? The 6 bolts on the body side of the hinge? Or both sets?
Because, for the life of me I cannot figure out how to get the tailgate to stay up, it keeps sagging.
ok......if it sags then you might need to shim it on the bottom side, if it is to upright then shim it on the top side
. Just get the bolts in to where the tailgate will stay up. I gently lifted the tailgate up into position with the bolts in the hinges, then shut it till it was securely latched (like how you would keep it closed normally), and then snugged the bolts up by hand while the tailgate was closed.
Well, it looks like I am going to stop working for the night. It's too late to be drilling, I wouldn't want my neighbors calling the cops or anything
It looks like I am drilling the holes for the latch side brace. I had to remove the carpet and weather stripping from the cargo area to drill to holes. I started those holes with a smaller bit (as I didn't want to use a punch and REALLY wake up the neighborhood), but after getting the little holes starts I decided that was a good stopping point.
Manoj, just for conformation... the passenger side, I don't have to remove that tail light do I? The instructions made it sound like I did, but I'm not sure what would go over there... is that latter in the instructions?
what more could you ask for
