OK bs
Old Mar 25, 2011 | 06:17 PM
  #4521
PainKiller's Avatar
Ok so I had to take the tie rod off on the passenger side to get the currie draglink to go to it's new home all I have left is torquing down the draglink to pitman arm and the draglink hold down adjustment bolts...then adjust it and test drive time .....thanks for all the moral support guys
Old Mar 25, 2011 | 06:52 PM
  #4522
PainKiller's Avatar
Seems the passenger side grease zert hits the tie rod so I will have to remove it until I find a solution
Old Mar 25, 2011 | 06:54 PM
  #4523
PainKiller's Avatar
Here's a pic
  #4524
u-joint's Avatar
Passenger side grease zerts of what?
Old Mar 25, 2011 | 07:29 PM
  #4525
PainKiller's Avatar
The new draglink...it's a currie HD and has greaseable joints
Old Mar 25, 2011 | 07:30 PM
  #4526
PainKiller's Avatar
Heading into Tulsa for a test drive
Old Mar 25, 2011 | 07:32 PM
  #4527
u-joint's Avatar
Never heard of it
Old Mar 25, 2011 | 07:34 PM
  #4528
u-joint's Avatar
Ahhh.... the drag link and tie od are too close and the zert is touching... gotcha.
That sucks
Old Mar 25, 2011 | 07:45 PM
  #4529
interceptor_1972's Avatar
...all I have left is torquing down the draglink to pitman arm and the draglink hold down adjustment bolts...then adjust it and test drive time .....thanks for all the moral support guys
Did you go back to a stock pitman?
Old Mar 25, 2011 | 07:47 PM
  #4530
u-joint's Avatar
I believe he did.
