Am I the the only one to grenade a Rubi front Diff?
Old Nov 5, 2008 | 06:24 AM
  #21
Rubicon Rando's Avatar
i have tried to contact some of the guys on here selling theirs but got no response... Pigina said he has a carrier, just waiting to hear form him.
60's may be an option in the future... at that point you can bet i will be running a much larger tire if not chromo's for sure
i guess you can say that i will never learn
Old Nov 5, 2008 | 06:28 AM
  #22
jkkat's Avatar
Just found out that my C's are bent after getting an alignment done, very minorally bent. RubyDoo is off about 1 degree on the right side and .5 degrees on the drivers side.
Old Nov 5, 2008 | 06:44 AM
  #23
RedneckJeep's Avatar
There was another thread on here somewhere that actually talked about people finding out the axle tubes are what's bending and not the C's.
Old Nov 5, 2008 | 06:45 AM
  #24
zeero's Avatar
Rando, I'm not here for points....but lets be honest.
The only way that you can possibly do the damage you did is by wheel spin and wheel hop with a sudden catch of traction.....thats the ONLY way man, and the only way for that to happen is by jamming the pedal because your stuck or trying desparately to get up that hill.
...."When in Doubt, Go Full Out".....right?
Look, I'm not out to point the finger, I'm merely indicating that with that kind of driving, there is no doubt that someone on the mechanical end at Chrysler will recognize the damage and the cause of it.....theres no way in hell they'd Warranty that.
Warranty is for failure of manufacturer equipment under normal, non abusive circumstances.
Again Rando, best of luck with that.....you'll need it.
  #25
Originally Posted by Rubicon Rando
Zeero... i award you no points... show me pedal mashing and i will eat my hat
redneck... i have asked them and reminded them... and nothing. another dealer is hopefully going to warranty it for me... hopefully and if they do... they will get all my future buisness
PiginaJeep... what do you want for it... you have a PM
Well I hope you get it worked out.....even though I think it was your fault. I promise you I was not making light of your situation. Good luck.
Old Nov 5, 2008 | 07:26 AM
  #26
SASQUATCH's Avatar
C-Gussetts and axle trusses would solve that lil problem, before it happens, why I did mine sooner than later
Old Nov 5, 2008 | 07:28 AM
  #27
thanks Redneck
fault or no fault... trail rated should satnd for something... no?
Old Nov 5, 2008 | 07:31 AM
  #28
4x4jkx's Avatar
Originally Posted by N2rock
See now, I don't understand how a dealer is able to sell a JK with 35's. The dealers are not capable of programming the computer for anything larger than 32" tires. So if they have 35's without changing the computer, then the odometer and speedo are inaccurate, and it is illegal for a dealer to sell a vehicle like that.
So I'm guessing that means they must be using an aftermarket programmer. But supposedly using aftermarket programmers voids the warranty.
Some programmers do some don't. The dealer probably got a manufacturer approved aftermarket programmer that won't void the warranty. Plus they are ASE certified mechanics... they have a code of ethics that they should be abiding by.
Old Nov 5, 2008 | 07:46 AM
  #29
armycop's Avatar
I don't think that any aftermarket programmer would be manufacturer approved. If you buy a programmer that changes the manufacturer's setting, you are choosing to accept the fate of voiding that part of your warranty.
As far as the topic, I think that if the dealer turns down the warranty work, and the fault is directly attributed to the modification, legally you will have no ground to stand on. If the dealer proves that the larger tire size placed more stress on the components, then you will be out of luck. That's why mod-friendly dealers are hard to find.
Old Nov 5, 2008 | 10:35 AM
  #30
zeero's Avatar
thanks Redneck
I agree...but that means, as built and tested by the Manufacturer Standard prior to getting to a dealership.
Here is a link to Jeeps "Trail Rated" ratings release....just an FYI
http://www.jeep.com/en/4x4/trail_rated/
To Chrysler....this means that it is specifically trail rated for nothing more than what is described.....not axle twisting 35's slamming over rocks and bouncing up hills at high speed.
I hope this helps.
