BDS lift kits
Old Feb 12, 2008 | 11:58 AM
  #21
Dropkick's Avatar
Originally Posted by bostonbuckeye17
matt...
i see you have a rubicon...i will too..once mine gets here...
if you follow the link i put up top...it says that it won't work with 2 door or rubicon... or 2 wheel drive.
so since we have rubicons...will it not work?
why won't it work? what is the reason? does BDS make one that WILL work??
The kit works on a Rubicon. There's just a part in the kit you won't need on the Rubi (I can't remember which part it is, but I originally read about it on here). I have the 3" kit and it seems great so far.
Old Feb 12, 2008 | 12:29 PM
  #22
bostonbuckeye17's Avatar
i talked to the 4x4 shop about it...and he called up bds.
they said that it will work on the rubicon..you just have to switch out the front and the rear control arms (or something..maybe it wasn't control arms).
but he said it would work.
Old Feb 12, 2008 | 12:32 PM
  #23
GRSuspension's Avatar
They fit on a Rubicon, if you order 2 rear sway bar link, replace the front one by those one.
The part you will not use is the Quick disconnect, because you will take the new link.
Like other manufacturer, you cannot take the factory rear one, because BDS dont replace it by longer one, but put a spacer between the sway bar bracket and the frame.
Old Feb 12, 2008 | 03:01 PM
  #24
ursandal's Avatar
It's just a basic 3" starter lift and should probably work fine. I'm pretty sure I have read other members on hear say that their coils were a bit on the soft side and tended to loose substantial height with the addition of heavy bumpers but then, no lift is impervious to some sagging. The only thing I would recommend is that you DO NOT use the cam bolts to set your caster. If you can and if you feel it's really needed, buy a set of adjustable front control arms and adjust your caster with them.
I was considering this lift, why not use the cam bolts?
Al
Old Feb 12, 2008 | 03:09 PM
  #25
Bluewaterrider's Avatar
Question Yeah??
Al
What exactly is the downside to using cam bolts with the stock control arms?????......premature wear on the rubber bushings???? what else
Old Feb 12, 2008 | 04:32 PM
  #26
JFRITZ's Avatar
Ok mow you guys have my attention as well. I have BDS's 2"BB and JUST ordered their 3" lift this morning...I put the cam bolts on with the BB and I also replaced my stock shocks with their upgraded 55 series that comes with the 3" kit..... I also just put their 3" springs in the front of my 4dr Rubi to "fix" the front end sag due to the Shrockwoks bumper and winch...
So what is the deal with the cam bolts? And should I assume that I will get the bad rake back sue to the spring fade?
Please HELP!
Old Dec 31, 2009 | 02:18 PM
  #27
GDK's Avatar
GDK
I just got the 3" lift and like it a lot. I use my car primarily as a DD and like the fact that it has a lifetime warranty. I had it installed by a dealer. Is there an option for rear disconnects too for this? I only have the front sway bar disconnects.
Old Dec 31, 2009 | 02:49 PM
  #28
spinlock's Avatar
Al
The cam bolts are an OK temporary measure, but if you go offroad they can be marginal in adjustment range and reliability.
There are numerous heated threads on this subject. Run a search for details.
Old Jan 12, 2010 | 10:53 PM
  #29
IcyFridge's Avatar
How are driveline vibrations or driveshaft issues with the BDS 3" kit? I am thinking about this lift kit, but do NOT want any driveline modifications or any extra parts/expenses. I just want to bolt it on and go.
Jeep is a 2dr JK with 6spd.
Old Jan 12, 2010 | 10:58 PM
  #30
IcyFridge's Avatar
I am looking into the BDS 3" for my rig. Since I want to run 35s in the future. Any driveline issues I should be watching for (driveshafts). Or is it install and go?
I would go with the 2" but that's kind of small.
