Brake Upgrades
EBay:
https://www.ebay.com/itm/Mopar-P5160...IAAOSw-89ZOMcj
Then if those don't turn out, individual Mopar part numbers.
MC
68048757AA
Booster
68048755AA
MC Reservoir (unsure if it comes with MC or not)
68048758AA
For Brake lines, I like the Mopars which came with the BBK because the lines fit onto the calipers with the proper bends. The Crown Calipers and Rotors are the same as the Mopar BBK, just missing the additional parts.
Brake Line Left
68184809AC
Brake Line Right
68184808AC
There's also a lot of good info in this thread where DaWhitesJKU did exactly what you're planning where the discussion of hoses came up with some pics posted of what other's used.
https://www.wranglerforum.com/f274/c...6-2155561.html
https://www.quadratec.com/p/mopar/br...-axle-P5160050
EBay:
MC
68048757AA
Booster
68048755AA
68048758AA
Brake Line Left
68184809AC
Brake Line Right
68184808AC
EBay:
MC
68048757AA
Booster
68048755AA
68048758AA
Brake Line Left
68184809AC
Brake Line Right
68184808AC
Y, all the retailers that still list that really don't have it. Technically backordered. My buddy with a shop just laughed at me about it saying "if that was in stock anywhere across the country, I'd buy every single one of them out!" I'll have to check the individual numbers, but I'm pretty certain if they were out there, my buddy would have found a way to locate them cuz he has a ton of demand. He swears the options these days are limited to the TF master cylinder paired with either the TF BBK or the Crown BBK (relative to the Mopar kit....I realize there are other options out there that don't involved replacing calipers). Thank you though. I'll look at this info more tomorrow during some down time at work.
I'm looking at the crown BBK and either the Teraflex BRK or the Dynaflex rear kit. I'm a bit daunted by the install of the Mopar mc & bb though, it sounds like a real PITA. In addition, the Mopar mc&bb doesn't seem to be available anywhere. That's making me lean toward the Crown mc or going with the Dynatrac Progrip system (pricey). Still on the fence which way to go though.
You bench bleed the MC which just involves mounting the MC in a bench vise, filling the fluid reservoir with brake fluid and pushing in the MC to suck in some brake fluid.
Then once it's all installed bleeding the brake lines starting with the caliper furthest from the MC and working your way to the closest caliper to the MC.
RR>LR>RF>LF in that order.
I never installed a MC or bled brakes prior. I just watched a few YouTube vids prior. I used the $20 hand vacuum pump from HF to bleed the lines. The tool was toast by the end but it got the job done and my brakes work/feel great.
Been installed going on 5 years now.
It did take me a good 8 hours doing everything including replacing my rear rotors, calipers and pads and using nothing but hand tools, but I also took my time doing it and watching some videos for a refresher as I reached each step. I did it all on a weekend to leave myself plenty of time if I ran into any problems.
I went from knowing hardly anything about brake systems to being kind of an expert on our JK brake system, so the effort and time spent was well worth it to me for educational purposes.
Considering I replaced the following items:
- front hoses
- front rotors
- front calipers
- front pads
- rear rotors
- rear calipers
- rear pads
- brake booster
- Master cylinder
- MC reservoir
My total out of pocket cost was around $1K but I also saved about $1K in labor costs if I would have had someone else do all the work for me. Really most of it was pretty simple and straight forward. Removing my rear rotors was the most difficult part since they didn't want to come off which you will need to do with any BBK which replaces the rear rotors.
Great thread!!! Wifey and I are buying our first Jeep, this week. After several months of research on Forums, Youtube and FB pages, I decided on going with a JK. It seems JK's are easier to mod, over the JL, as well as having a myriad of aftermarket support.
Bigger brakes are one of the first 3 mods I will be performing when we get our JK home. Knowing how extra rotational mass, by adding bigger wheels and tires, affect braking, a BBK is necessary, for sure. Thanks for all the great info.
I agree, I don't think the Mopar kit (mc & bb) is available anymore. That only leaves the Crown mc or the Teraflex. I think mc on both of those are the same diameter. Any thoughts on the Teraflex BRK? Is the quality suspect?
I have a good friend that has the Teraflex installed, and another good buddy with a reputable shop that installs quite a few of the various brake options. There should be zero concerns about the quality of the TF kit in general, it's just a little pricey.
The Mopar BBK was originally a J8 brake upgrade only available as an option in Europe. Maybe since the JK is no longer being manufactured they stopped making the Mopar BBK as well.
With that said, working for an auto supplier for Toyota, we are required to manufacture parts for 15 years after the vehicle production ends for service parts. For accessories its 10 years. I have to imagine FCA has a similar policy, but those parts may only be available through Europe sources if they did indeed stop offering the Mopar BBK as an accessory for the JK...and this is FCA afterall and not Toyota...but I'll give them the benefit of the doubt.
I know I'll be pretty ticked if I can't get a replacement MC or Booster if ever needed. I doubt production has completely stopped. Just not as frequent builds being done.
