Plug and Play Remote Starter $100 on ebay
Old Feb 13, 2014 | 12:12 PM
  #171
Woodbutcher's Avatar
Originally Posted by jmill012
Perfect! Thank you!!
I almost spliced the wire on my Jeep harness and then realized everyone said it wasn't on the Jeep harness.
I need a few
I think I am delirious from shoveling out of 2 feet of snow.
Yeah, splicing the jeep harness would be bad. :doh
Old Feb 13, 2014 | 12:40 PM
  #172
Vladimer's Avatar
Originally Posted by Woodbutcher
Make sure your getting the same setup as everyone else, not sure if you saw my edit above.
I used 4lo and Neutral to test the system..my plan is to use a relay. pin 86 is your key on hot, pin 87 is your ground output that goes to clutch, I want to switch this as well. 30 and 85 go to the e-brake, or 1 to ground and 1 to brake.
I did miss your edit, but I called him back just to be sure and it is the CHR5
Which pin are you planning to put the relay on? I assume 15, 14 would be the normal choice. Pin one on the ignition would be the safest though but that would involve splicing into the wire for possible no extra gain if 15 and 14 are free.
Old Feb 13, 2014 | 01:03 PM
  #173
No, the relay it's self...sorry if I confused you.
I plan on buying a relay say, for lighting. Supply keyed power to #86 on the relay and ground to #'s 30 and 85 using the e-brake switch wire. # 87 becomes a ground that would be tied into the wire that you use to ground the clutch. My thinking is, apply the e brake, put in (N) you hit the remote start button it supplies power to the relay which in turn grounds the clutch. I want to put a toggle switch to break ground as well (2nd precaution).
I just reread your post...I think i'm confused LOL. The short answer would be i'm not sure yet.
Old Feb 13, 2014 | 01:18 PM
  #174
Sand Scorpion's Avatar
wow thats alot of work you sure it wouldn't be easier to trade your jeep for an automatic?
Old Feb 13, 2014 | 01:34 PM
  #175
No, not really I find auto boring. lol The unit works out of the box but, theres no safety precautions, and you have to trick the jeep into thinking the clutch is pressed. This is just a glorified bypass switch, but it makes me use the e brake and turn on a switch to make it work.
Old Feb 13, 2014 | 01:45 PM
  #176
Vladimer's Avatar
lol, sorry. I was referring to the pins on page 2 of the link you supplied to the evo manual.
By far ... no. I would never swap into an auto.
Old Feb 13, 2014 | 02:31 PM
  #177
BAMA1111's Avatar
Got my unit in today from Car Alarm Depot. Took about 20 minutes to install (2014 JKU) and everything worked perfect. So glad I can get in after A/C has cooled things down.
Old Feb 13, 2014 | 03:32 PM
  #178
Got mine installed just now 20 minutes works great.
Old Feb 13, 2014 | 06:08 PM
  #179
jmill012's Avatar
Got mine installed. Finally!
Old Feb 14, 2014 | 04:38 AM
  #180
For those of you who don't want to hear the horn chirp the three times need to start the jeep.
Sound Horn On Lock
This feature will cause the horn to chirp when the doors
are locked with the RKE transmitter. This feature can be
turned on or turned off. To change the current setting,
proceed as follows:
• For vehicles equipped with the EVIC, refer to “Electronic
Vehicle Information Center (EVIC)/Personal
Settings (Customer-Programmable Features)” in “Understanding
Your Instrument Panel” for further information.
• For vehicles not equipped with the EVIC, perform the
following steps:
1. Press the RKE transmitter LOCK button for 4 to
10 seconds.
2. While the LOCK button is pressed (after four seconds),
press the RKE transmitter PANIC button. Release both
buttons.
The “Sound Horn On Lock” feature can be reactivated by
repeating this procedure.
