Superchips Error - Car is dead -HELP
Old Jan 2, 2014 | 03:57 AM
  #51
2013Sport's Avatar
No updates from me. I have not had time to pull the PCM since I was out of town for 10 days for the holidays.
Old Jan 2, 2014 | 03:58 AM
  #52
2013Sport's Avatar
Originally Posted by Indavis01
Well, my JKU is bricked as well...... 2013, I have a stock radio, in fact i have no electrical mods at all. One thing in common though, Had it programed with a Flashcal which i removed to do the Flashpac, Only used the Flashcal because for the tire correction. I can't even get mine to turn on- Getting the "NO BuS" error on the panel and the #E-55 error.
Probably shouldn't have been screwign with it on a friday night......
Have you talked to Superchips?
Old Jan 2, 2014 | 02:51 PM
  #53
Indavis01's Avatar
Default Update on Bricked JKU
I talked to superchips today as this is their first day open since 12/24. Tried uploading new software with their techs 3 times, was finally told to remove my ECU and send both the ECU and the programmer to them......um...ok, Its a six month old Jeep. I am not pulling the ECU myself. Finally they came back and said to have it towed to the dealer and they would pay for a reflash. Hopefully that works.
Oh I got it running and dropped it off at the dealer, On another forum there is a workaround to get the jeep to essentially limp- using any programmer or DTC reader, you can clear the DTC's and it will start and run in diagnostic mode. I only had to go 1/2 mile to the jeep dealer.
I'll let you guys know how it goes....
Old Jan 2, 2014 | 03:21 PM
  #54
jadmt's Avatar
JK-Forum Ambassador
yea that could be ugly. what did the local jeep dealer say? were able to get you back up and running? I would be worried about having warranty flagged on a new jeep.
Old Jan 2, 2014 | 03:39 PM
  #55
7kings's Avatar
I'm wishing you luck on this, and I'm not trying to throw bad juju your way, but I wouldn't expect to drive away with much of your Jeep warranty intact after the dealer flags your VIN. The minute you modify your PCM programming, all bets are off.
Good luck - let's hope you get hold of a cool dealer.
Old Jan 3, 2014 | 04:08 AM
  #56
2013Sport's Avatar
We are in the same exact situation. The dealer couldnt help me though, their programmer could not talk to my PCM. It is my busiest time of year at work so I have not even had time to pull the PCM, I just want the damn car fixed.
They are about a 3.5 hour drive from me. I want to call them and say hey, I am driving up Sunday (my only day off), can you have someone there to fix it.
Old Jan 3, 2014 | 05:35 AM
  #57
jadmt's Avatar
JK-Forum Ambassador
they offer such a good warranty in there propaganda you would think they would send some one to your house to fix it.
Old Jan 3, 2014 | 06:18 PM
  #58
2013Sport's Avatar
Just to confirm this is the PCM correct?
I will disconnect neg battery terminal and no key in ignition while removing. Click image for larger version
Old Jan 3, 2014 | 06:29 PM
  #59
karls's Avatar
Yep, that's your PCM.
Old Jan 3, 2014 | 06:46 PM
  #60
tklein42's Avatar
I cant believe the shit you guys have gone through. They should send you a fucking PCM while they troubleshoot your issue! Bullshit!
