Superchips Flashpaq for JK, Initial Impressions
Old Aug 5, 2011 | 12:20 PM
  #2071
Tuto's Avatar
Originally Posted by SilverJK12
Thank you, which one did you buy
The Motorad brand number 1601-24338
(340180)
Made in Israel.
You have to remenber that if U reside in place were the temperatures get very cold you should change the thermostat back to the 195* F during the winter.
Old Aug 5, 2011 | 08:38 PM
  #2072
sea bass's Avatar
Finally put mine back to stock after a full year of constant knocking. What a difference! Soooo smooth and quiet now! I don't feel a bit of power difference from 87 tune and stock - just throttle response like some have said.
Anyhow, just using it for my speedo now...
Old Aug 5, 2011 | 08:56 PM
  #2073
RL_in_DWG's Avatar
I have been running the 87 tune for a few weeks now. I have an 07 2-door with 3.21 gears, 285/70/17 (33s), and an MBRP cat-back. The jeep runs nicer now and is more enjoyable to drive. I have hand-calculated 19.8 mpg on a tank of gas. I used to get 16-17 before the superchips.
Old Aug 5, 2011 | 09:26 PM
  #2074
JeepPilot10's Avatar
It sounds like rough engine performance is a possibility with the chips. I guess factory settings can be reinstalled.
Old Aug 5, 2011 | 10:14 PM
  #2075
Bauker's Avatar
I ran the 91 tune and I noticed some pinging under full load in 108* weather. I ordered some Torco to up the octane to 95 and Ill give the 93 tune ashot just for fun. Ill probably settle with the 91 tune and just adjust the ping out with timing. I still gained 2-3mpg with the 91 tune. I tried the xs mileage tune and was getting 18.8mpg hwy. I'm extremely happy with what it has done performance wise, not to mention fixing my speedo and adjusting TPMS.
Old Aug 6, 2011 | 01:39 AM
  #2076
tahoe_jeeper's Avatar
I have been running the Flashpaq on my 07 2D Rubicon for 1 year now. Works great in the 87 Power and Economy settings and have seen about 2 MPG economy gain.
The one issue I have had is when i reverted to factory settings the last two times it resulted in the speedometer no longer working until i reprogrammed it. Makes for lots of questions when taking in to dealer sservice.
Old Aug 10, 2011 | 06:29 PM
  #2077
pik's Avatar
pik
Finally after getting my unit to recognize the Jeep, i had a chance to run it for a week on the 87 octane tune.
Definite difference in throttle response; less lag. I have felt a difference in pick up from a start through 1st and second gears. No big difference while on highway while in 6th gear. I will have to take a trip up the mountains to see if I will have to down shift on some hills that I normally had to.
I do like the options that the unit gives you. I am looking for a set of 35's; it wll come in handy to calibrate speedo.
I have not changed anything else with unit
Will check back with any mpg changes after running several tanks of fuel through it.
.....I have a 6 speed JKU Rubicon with stock swag
Old Aug 10, 2011 | 10:39 PM
  #2078
Berserker's Avatar
I've had the 97 tune for 6 months in my '07 JKU with no issues. Performance gains weren't worth the cost.
On a side note, I'm not throwing any codes with a Viper throttle body.
Airaid CAI
MBRP offroad exhaust
Did have E3 spark plugs for a few months but two went bad & caused misfires. Back to OEM Champ's.
Old Sep 4, 2011 | 04:18 PM
  #2079
topgear's Avatar
When you use the flash PaQ once is code to your jeep or not had mix answer?????????
Old Sep 4, 2011 | 08:19 PM
  #2080
RubiDude's Avatar
It is in fact "locked" to your VIN...unless you remove and restore it from your JK. I, for example, ran it for about two weeks and sent it back for a refund...They were very clear about making sure that I sent it back into them reset or I would not get my money!
