Superchips Flashpaq for JK, Initial Impressions
I pull the tune out before i leave for the dealership. Allows it to reset some of the obd ii readiness codes on the drive so it's not 'so obvious' that someone just cleared the codes on it. Also, i pull the fuse for my locker hack, since that also throws a code (which i clear). That way they cant hit the 'what is this button' and come up with a potential problem for me.
Just got back from my initial test ride after flashing my Jeep. I have been waiting for nearly a month for my SC to arrive (took over a month for the unit to arrive in the mail to the UK). Initial impression… all smiles. Just did the quick tune option with 91 octane, and can feel the results. Nice response on the gas pedal (gone is the bungee feeling), acceleration is what I expected a new JK to feel like from the get-go, and already seeing a slight rise in the MPG. Will leave it tuned to where I have it now, and see if I would want to change to the tow tune later. Just about all of the posts to this thread have been informative and helpful, prompting me to try the SC Flashpaq. Thanks for sharing, and I’m pleased with the purchase and newly obtained performance boost.
that is useless if you are trying to hide anything. none of your readiness codes will be set, and they can see that very easily. if you are doing it that way, dont bother returning it to stock at all. Takes around 3 full cold/hot cycles to reset them all properly.
I doubt the dealers are going to go on a mission looking for evidence of a tuner, but they will at times install updates. It's the updates that I have concern with and with a tune installed they run the possibility of bricking your JK, or at least not being able to get their update installed which throws up a red flag.
Personally, I'm not worried about driving around, and just pull off the road around the corner and return to stock before I get there.
If for some odd reason they did happen to 'brick' it it would only be temporary - they have a way to install a full version of code onto the computer to get it back to the base calibration that they need to run the vehicle - it would just take a little more time to get it flashed...
Yep, the dealer should just write over your Flashpaq code. The problem is your flashpaq stock settings will then not match your new stock settings, and it assumes you are trying to program a second vehicle. Of course you can send it back to them (SC). I'm sure they will fix it for a small fee.
Since they lock the programmer with the vehicle VIN I would have to assume it works like other programmers where it would still work on that vehicle - it would interrogate the VIN number of the vehicle and if it matched the version stored in the programmer then it would read the code / version and determine if it had a program to update that particular version of code and if not they'll get the message to contact SC... I don't know about this Superchip programmer in particular but that's how others in the industry do it so I can't see them doing something different...
I just received mine last Friday and am happy so far with the results. I didn't expect the performance to be noticeable better, but I did get the tire size corrected and all the driveability has improved a lot. The JK is no longer constantly looking for the right gear and bogging down when climbing a hill, that to me is worth it alone. I applied the 87 tune to the JK and am pleased.
I've heard several people say the 91 octane tune is worth it for mileage and performance. Has anyone compared both the 87 and octane tune? Is it noticeably better and with the mpg increase, does it offset the higher cost of fuel?
Now if only I could give Superchips customer support the same positive review I gave their tuner, but sadly I cannot, and that's all I'm going to say here about that.
Tom
I'm on my third tank of 93 Octane with the 93 Octane Tune. For performance it is my favorite but the MPG gains are minimal if any. It holds interstate speeds well and has just all around better response. I've seen only about 1 mpg improvement on average.
I had reported pinging on the 87 tune, which was alleviated by running mid-grade. This was in Dallas. I recently moved to Evergreen, CO so I now live at 7700' of elevation. The 87 tune pings even with premium (91) here. I just bagged it and reverted to stock. Any minimal "improvements" won't be worth it if I grenade an engine.
I'm going to just sell mine I think...
