Superchips Flashpaq for JK, Initial Impressions
Old Feb 27, 2013 | 09:32 AM
  #2471
xerofall's Avatar
Okay, I switched to the tow tune, filled up with 91 octane and resized my so called 33 inch tires to 32 actual. Got my GPS unit out and tested the speedo, all is good. The GPS read 39-40 and my needle was at 40 exactly. So I'm happy that my speedo is calibrated. (I also tested at 20, 25 and 30)
Old Feb 27, 2013 | 10:24 AM
  #2472
eumel789's Avatar
Very good point! Most people forget that the speedo/odometer is way off with larger tires! You can't really calculate MPG if the distance traveled is wrong!
Old Mar 17, 2013 | 06:43 PM
  #2473
slogoinco's Avatar
I have been quite impressed so far. I am only using the 87 tune and recalibrated for 285/70/17's and 3.73 gears.The tranny settings are much better and the correlation between the gas pedal and what it is telling the TB to do is much better.
Old Mar 19, 2013 | 06:26 PM
  #2474
numumzu's Avatar
Question:
I have my jk flashed. I need to take it to the dealer to get a couple of new keys programmed.
Do I need to put it back to factory before getting new keys?
PITA
Old Mar 20, 2013 | 07:37 AM
  #2475
zedteamk2's Avatar
Yes, if they change the programming in any way, the flash pack wont recognize it.
They reccomend to return to stock everytime it goes to the dealer, in case they install an update
Old Mar 20, 2013 | 10:42 AM
  #2476
numumzu's Avatar
Thanks for confirming this.
I just need a new key.....
Old Mar 21, 2013 | 11:03 AM
  #2477
soadxtr573's Avatar
I know it's probably in here somewhere (in the 247 pages...), but could someone let me know what mpg they're getting with the 87 tune? I just moved and my work commute is longer and packed with traffic, so the 93 tune has been pretty unfriendly to my bank account. I'm getting about 15.5mpg (highway only) with 33's, an airraid cai, spidertrax spacers (I heard not great for our non-existent aeros), and an mbrp exhaust. I'll switch back to the 93 when I get my raise or new job :P.
Old Mar 21, 2013 | 03:58 PM
  #2478
eumel789's Avatar
The best I do is about 16 on the highway with my 35's and the 91 tune.
Why don't you just change to the 87 and find out for yourself??
Old Mar 21, 2013 | 06:11 PM
  #2479
Croce's Avatar
With my 3.5" lift and stock rubi tires i get a about 17-19 highway using the 87 tune. Probably about 1 mpg less if I use tow tune (87 octane gas) Most the time I can get 19 if there's no hills and I keep it under 65
Old Mar 27, 2013 | 07:24 PM
  #2480
wuzzzer's Avatar
Just bought a Flashpaq for my stock '08 JKU. What can I expect and what's the recommended tune to use?
