Superchips Flashpaq for JK, Initial Impressions
Where can you find the TPMS disable in the Superchip? I have downloaded all the updates and even downloaded the TPMS disable portion and can not locate it when plugged into the Jeep. I still have the part where I can select tire pressure from 26 on up, but can not locate any way to disable the light.
One other thing noticed is that every once in a while when I start the Jeep the TPMS light is not on at all, then all of a sudden out of the blue it pops back on sometimes and sometimes stays off. I do not have any TPMS sensors in any of the rims. Anyone else run into this issue?
That's a time out error where the PCM didn't communicate back to the Flashpaq in the prescribed amount of time. Make sure you have a good charge on the battery by perhaps running around for 15-30 minutes then try again.
Well I have some bad news for you. The disable feature only works if you still have the sensors installed. Because it disables the sensors! Without the sensors present it cant shut them off.
This also happened to someone when using AEV ProCal and they did not have the sensors installed anymore.
One thing that makes me scratch my head is that why isn't Chrysler doing this from the production line? Safety? Fear of Lawsuits?
Finally got my Flashpaq installed and working. I had to have my factory ECU reflashed. They told me that it was 4 Versions behind. I went straight home and WaaLaa...I can tell a hugh difference in the shift points. Makes what felt like a slug more like a turtle
