Superchips Flashpaq for JK, Initial Impressions
Old Oct 12, 2009 | 09:36 AM
  #951
08leocon's Avatar
Originally Posted by alim10004
I am still sitting on stock 32s, about to be upgraded to 35s (hence the --> in my signature). Apologies if it was misleading.
So my suspension and tire size is still stock for the next 2 weeks.
The only performance deltas i have from stock are :
MBRP exhaust
Snorkel (RAM).
Don't get me wrong, i'd love to be able to run leaner like i do an airplane engine. But what we have here are highly subjective interpretations of performance.
I would love to get DYNO data for performance.
EGT data for leaner tune (and hence hotter).
If someone went to the trouble of doing that, it would be great to see the data.
For the Auto-transmission, i have no experience but wouldn't disagree if the shift-point RPMS come down a notch, ending up with higher MPGs.
As we all know the tire size stated is never the actual tire size. the stock rubie 32's are 30.5 when i got my superchips i checked stock seting ,low and behold the tires were set at 30.50 i measured and right on, that being said i put on BFG KM2's 35x12.50.17 factory specs say 34.8 , on a 17x9 inche wheel with tire preasure stated on the side of the tire.
The shop that did my lift and tire wheel install recalobrated my speedo to 35's' i checked my speedo with gps and was way off had to change them to 33.50, so i measure again' useing flat ruler across the top of the tire and measure to the ground,low and behold 33.50.
My points is my 35's are not true 35's but my 32 rubie stockers were only 30.50 so i still got a 3 inche taller tire from what is called 32 and what is called 35
Old Oct 12, 2009 | 10:41 AM
  #952
Atl JK's Avatar
Originally Posted by Dr Diggler
I am at around 2500 ft.
I am also submitting my problem on the flashpaq forums. I will submit what Ron tells me here.
Interesting. I'm at 5400' here around town and in the mountains I've been over 12000' with no pinging. I had light pinging once, but I think it was just a tank of bad gas. I filled it up at some no name rural station in the mtns.
Old Oct 12, 2009 | 12:16 PM
  #953
Ge99ne's Avatar
Originally Posted by spinlock
As far as I can tell the MPG meter on the dash only displays the a rolling average over the last few miles and it doesn't do it very well at that because every time it updates the MPG value it only changes is small amounts.
At least on my JK, if I drive with a really heavy foot, the in dash MPG meter just ticks down slowly every few miles. If I then drive normally it continues to go down for a while, but a some point it starts to tick up very slowly.
It seems like the only time you can rely on the MPG indicator is when you are on a long trip and your speed and the terrain are pretty constant.
Am I missing something? Does the Flashpaq change this behavior?
Reset the MPG indicator and it will change much faster. You may have hold it in a second time to reset it. Based on your desription of it's operation, you've never reset it. It will update (visibly)about every 2-3 seconds after a reset. The longer you have let it run the worse or better you have do drive to affect the average. (which is what it displays). It will jump by as much as .5 to .8 mpg after a reset with a major change in driving. If you reset on the highway then coast down an exit ramp, you can get into the low 30 mpg range. Lead foot it at a stop light after a reset and you can get it down to about 7 or 8. All this was to say it's constantly updating, but you have to reset often to see a more active meter. Also many people on the forums find the indicator to be 1 or 2 mpg optimistic.
Old Oct 12, 2009 | 12:38 PM
  #954
Ge99ne's Avatar
My impressions :
1) For auto-transmissions, you'll probably see slightly more mpgs because the shift-points get re-adjusted to lower RPMS.
2) For manual transmission, i don't see any difference by "allegedly" running leaner. Unless you have an exhaust gas temp gauge (like in piston - engine aircraft where you have to adjust your fuel-air mixture by altitude ), you can't tell if you're actually running leaner.
3) If the MPGs were really true and its purely software, Chrysler would jump at the chance to sell their jeeps stating 19 City, 24 Highway. They aren't doing that not because they're lazy but because this is snake oil.
Experience :
I have run this for the week on my 2007 6 Spd Rubicon and while the MPG gauge was claiming 24 mpg on the highway, the math worked out to the usual 20. Obviously its much easier to fudge the dash numbers than produce real performance or economy gains.
If anyone has put this on a DYNO and to an exhaust gas temp gauge, i'd like to see the data.
Humbly my $0.02
I may have missed some other post here, but are you saying there was no discernable change after running the tuner. You seem to be doubting any chance of a mpg increase, but I was wondering if your butt dyno had not registered an increase in acceleration.
I'll speak to the auto tranny side of the tuning equation. It increases rpms in general. Which definately helps motivate my jeep. The only time it's decreased rpms has been it's ability to stay in od a little longer. The gas pedal definately became more sensitive after the tune. In a good way I might add. I can tell the difference under full acceleration on highway on ramps. I got the tuner primarily for tire calibration and code reading. I was expecting nothing out of the tune & was really surprised how different the shifting, and acceleration felt.
Old Oct 12, 2009 | 02:08 PM
  #955
JPop's Avatar
I'll run it on 93 this week with stock tuning.
Then i'll run 93 with 93 tuning.
Dyno - if results don't exist, that's where i end up. I was hoping they do. If they don't that's ok. I 'll end up doing them.
If you're doing tests it's best to burn through a full tankful at the same setting before you record your results. PCM re-learn can take 150 miles or more to complete. With my tests, I feel pretty comfortable with the second tankful, but the third tankful is more indicative of what prolonged use will bring.
Also, if doing dyno tests, it's important to roll the vehicle around before executing your SC or other programmers tune. I would roll through a half an hours worth of spirited cruising and several freeway onramp blasts to hasten the PCM re-learn and have results that are meaningful.
Old Oct 12, 2009 | 02:49 PM
  #956
jason0341's Avatar
Hey just curious to what people are running 285/70/17 Bfg Km2's at? PSI and size for the Flashpaq? I have mine set at 32.50 for the Flashpaq seems about right. Any suggestions on your use. I have also done the chalk test for psi running at 35 for street.
Thanks in advance
Old Oct 13, 2009 | 02:46 AM
  #957
JPop's Avatar
Thanks in advance
I'm not running those but 32.5 seems like it would be a little tall. Measure from the ground to the top of the tire and that should get you pretty close and if you have access to a GPS use that to dial it in the rest of the way.
Old Oct 13, 2009 | 12:32 PM
  #958
spinlock's Avatar
Thanks in advance
The spec height for those KM2s is 33". Although this may not have a noticeable impact on the Flashpaq tuning, unless you are running above 35psi, I would be really surprised if the actual height of the tire the vehicle is 32.5". Did you actually measure the height?
How is your ride? At 35psi my 35" KM2s start to feel like I am ridding on knobbies, although it sure reduces the rolling resistance.
Old Oct 13, 2009 | 12:50 PM
  #959
jason0341's Avatar
My ride is fine with the PSI at 35, I took a level to the top of the tire at leveled it up and then measured from the ground to that point. I am somewhere in between 32.25- 32.50 for them.
Old Oct 13, 2009 | 10:01 PM
  #960
spinlock's Avatar
That's close enough to 32.5". I'm just surprise because my 35s are close to a 70 series profile and I get more sidewall flex at the same tire pressure, since they measure less than 34" using a very similar measurement process.
I currently only have the ProCal, and it take tire measurements to within a quarter of an inch, so maybe that is the threshold of the PCM.
This thread has convinced that the Flashpaq has the features that I am looking for. A few hundred posts ago on this thread someone jokingly posted that we were headed to 1000. I thought to myself: Yeah right, if it hits a 1000, I will buy a Flashpaq (something I was planning to do late late this year). I guess it is almost time to pay the piper.
