New! Soon to be Released 2012-Up JK Bolt-on Air System
One of the forum members, azsandrider, was kind enough to bring over his 2-door Jk for me to check it out. Thanks for that!
I am bummed to have to mention this, but the system will not work on a 2-door. All of our fitting was on a 4-door. We are however, going to work on a set of brackets to adapt this to a 2-door. Not sure on time frame, but is on our list of things to do.
To all those that pre-ordered, I will be calling you tomorrow with shipment details.
Thanks again guys and more to still come as far as photos, etc.
The compressors themselves are moisture and dust resistant, and very well sealed up against the elements. The kit will come with remote filter kits, that must be used, to locate the filters in a dry location in the cab. From there, just make sure to not have them running while submerged.
Also, just to be clear: is you are crossing waters and everything is submerged for few minutes, providing that the system is not operating, we should be fine?
Thanks
I went by On-Board Air's place to check how the air tank & compressor fit and as he stated above, it will not fit on the two door. BUT, he checked his measurements with all my modifications (3" Teraflex long arm and complete Rock Hard skid plates) and his system will work with all the mods IF I had a 4 door....
I will say he was very nice and the system he has designed is well made with good parts, it just won't fit on my 2 door.
There is room at the rear of my 2 door where the muffler is, but I would have to relocate the muffler and have brackets made for the air system.
For 2 door owners, it looks like a Warn Powerplant on the front, or the ADA system under the hood (very narrow clearance), re-locating the muffler for this system, packing a portable compressor or air tank inside which takes up space, or hanging the air tank or compressor on the rear rack/tire carrier.
I like a stream lined look so the rear rack/tire carrier with a tank or compressor doesn't appeal to me. I don't like the clearance of the under hood ADA compressor and I don't want to take up extra room inside as I often camp as I need the room for other stuff. So I'm probably going to get the Powerplant and synthetic cable to lessen the weight.
I wish On-Board Air's system would have fit my two door as that would be the way to go....
Here are some photos of the assembled system, as it would be before bolting it up to the Jeep.
