snow chains
Old Dec 3, 2007 | 01:07 AM
  #21
Tommy3rd's Avatar
Install chains on rear tires only. Tire chains may be
installed on all models except the Sahara and Rubicon. Use chains on P225/75R16 tires only. P245/75R16,
P255/75R17, P255/70R18, and LT255/75R17 tires do
not provide adequate clearance.
so, it says you can install it on all models except the sahara and rubicons..so in other words, use it only on the X.
Not enough clearance for 17" and 18" tires, so in other words use it only on the base model X without the S package.
why can't they just say "install on base model X with 16" tires only".
Old Dec 3, 2007 | 03:49 AM
  #22
nepatsfn's Avatar
That would be way too easy
Old Dec 3, 2007 | 12:27 PM
  #23
csorensen's Avatar
No, they would have to say, "Intall on base model X with 16" tires only, IF SOLD IN THE UNITED STATES"
Seriously, VOODOO has 17 inch wheels, and the 255/70 tires, and his manual doesn't say not to use chains. HMMMMMMMMMMM
Old Dec 4, 2007 | 12:11 AM
  #24
Voodoo's Avatar
I'll try to put them on and snap some pictures to post here as soon as I get a chance...
Old Dec 4, 2007 | 10:40 AM
  #25
coltc2000's Avatar
the reason for not using the chains due to clearance is Chain is loose
Cable you can get much tighter. manual says nothing about Cables.
Old Dec 5, 2007 | 01:13 AM
  #26
Voodoo's Avatar
Here's a picture of the chain mounted on the rear. It gets pretty tight !
I'll go to see my tire guy and ask him what HE thinks.
Asked Jeep dealer yesterday 'bout this and he asked Crysler Italy and the answer was:
"Even if not written in owners manual the Rubicon is NOT supposed to mount chains."
I wonder what happens if someone in Italy puts chains on his Rubi and rips them off destroying the braking hose or something else...
Old Dec 5, 2007 | 10:49 AM
  #27
csorensen's Avatar
WOW, that is really tight. I see the reasoning now.
Looks like it's going to be cables for me next fall then...
Wonder how having different wheels/tires affects this clearance.
Old Dec 5, 2007 | 11:42 AM
  #28
moun10eer's Avatar
I often go to Cascades mountains for backcountry skiing/snowshoeing etc. during the winter, but I've never used chains on the pavement.
That said, I usually carry chains just in case. I like GoCraws (flextrax "dot" com) because it's very easy to put them on (even when the tires are covered in mud/snow). It doesn't look like they provide much traction, but they actually work... as good as chains or cables. When I went to climb Mt. Langley in High Sierra in late fall/early winter a couple of years ago, I got stuck on the NF service road with mix of snow and mud (underneath). I was able to recover without much hustle thanks to this thing.
Old Dec 5, 2007 | 01:00 PM
  #29
Lawman's Avatar
I contacted Chrysler direct and just received a reply to contact my dealer and inquire as to why chains are not recommended and to find out what modifications to my vehicle, if any, can be made to accomodate chains. Regarding the cables, they were not made for the 265/70/18 tires.
Interesting problem for a "go anywhere" vehicle. I guess that excludes most resorts.
Old Dec 5, 2007 | 01:24 PM
  #30
08JK's Avatar
I'v driven many times in the snow in my old TJ(s) but never had to use my snow chains, although they're always in my Jeep because the law requires you to have it.
