2012 Wrangler information thread
Is it me, or is it crazy that jeep has sent the 2012 model over to China first and it was photographed before it has even been sniffed in the US? Why don't they send the 38K 2011's they have over there and give us the 2012!
According to a local dealership (Houston, TX), the Call of Duty option was available on day one as package id "24v." Although the dealership ordered this package, it was promptly cancelled, and 24v was deleted from the ordering system. I can only assume that because Call of Duty: Modern Warfare 3 is scheduled to be released in November, the earliest we would be able to order this package is August/September.
I ordered a Jeep Wrangler Unlimited Rubicon today, and I must say, the range of options were pretty sparse. (I sat next to the guy ordering, and saw every option available.)
The 2005+ Grand Cherokee has the autostick. I had a 2005. Its a great feature. It looks like this 2012 has that, you move it to the left to downshift, right to upshift. It was a necessity for off roading in my opinion.
Hi
From a Grand Cherokee?
Autostick for Grand Cherokee explained.
"Autostick
Autostick is a driver-interactive transmission that offers manual gear shifting capability to provide the driver with more control. Autostick allows the driver to increase engine braking ability, control upshift and downshift points, and enhance the driving experience. This system can also provide the driver with more control during passing, city driving, mountain driving, trailer towing, and many other situations.
Autostick Operation
By placing the shift lever in the D (Drive) position the lever can be moved from side to side. This allows the driver to engage the AutoStick mode. Moving the shift lever to the right (+) or the left (-) will engage the Autostick mode. In normal driving mode (Boxed “D” displayed in the PRNDL), moving the shift lever to the right (+) will engage the Autostick mode putting the transmission in the currently engaged gear. Moving the shift lever to the Left (-) will engage the Autostick mode and downshift the transmission 1 gear. For example, the transmission is in Normal Mode and is currently operating in 3rd gear, a boxed D is displayed in the PRNDL, a push to the right will engage the Autostick mode in 3rd and a Boxed 3 will be displayed in the PRNDL. A push to the left (-) will engage Autostick mode and downshift to 2nd gear and a Boxed 2 will be displayed in the PRNDL. Once Autostick mode is engaged a move to the Right (+) or left (-) will trigger a upshift (+) or trigger a downshift (-).
NOTE: In the Autostick mode, the transmission will only shift up and down when Left or Right (D-/D+) is manually selected by the driver.
The transmission will not honor a downshift command if the downshift would result in a engine overspeed condition. The transmission will always honor a upshift command from 1st to 2nd gear, however 2nd - 3rd, 3rd - 4th, and 4th – 5th upshift commands will not be honored if the vehicle speed is to low to maintain operation in the commanded gear. The transmission will automatically downshift as the vehicle slows to a stop.
When in the Autostick mode, as the engine RPM nears the engine maximum speed, an “UPSHIFT” message will appear in the Electronic Vehicle Information Center (EVIC) portion of your instrument cluster. This message appears in order to alert the driver that the engine speed is approaching it’s maximum value and a upshift to the next gear is required. In the event that the driver does notupshift, the engine control system will limit the engine speed to protect the engine.
Shifting into or out of the Autostick mode can be done at any time without taking your foot off the accelerator pedal. When the driver wishes to engage Autostick, simply move the shift lever to the Left or Right (D-/D+) position while in D (Drive).
Hold the shift lever to the right for at least one second to disengage Autostick. The transmission will now operate automatically; shifting between the five available gears.
Autostick General Information
You can start out in first or second gear. The system will ignore attempts to upshift at too low of a vehicle speed. The transmission will automatically downshift to first gear when coming to a stop.
Starting out in second gear is helpful in snowy or icy conditions.
Avoid using speed control when Autostick is engaged.
The transmission will not automatically shift up when maximum engine speed is reached while Autostick is engaged.
Transmission shifting will be more noticeable when Autostick is engaged."
From
http://www.wkjeeps.com/wk_transm.htm
Best regards from Sweden
Omar Brännström
"Autostick
Autostick Operation
From
Omar Brännström
