Cheapest Evap Relocate!
Old Nov 2, 2009 | 11:08 AM
  #61
ifshinxs's Avatar
Originally Posted by Woods
So nobody gets confused. My kit also flattens the factory bracket, Instead of hammering it out, you cut one end off and replace it with a flat adapter plate.
I just checked the install on your relocate kit...Very nice!
Your right.. You would have to compress the bump stops to hit the canister.
Old Nov 2, 2009 | 12:06 PM
  #62
hansen65's Avatar
Here's my take on it. At full compression (driver and passenger sides fully stuffed) and compressing the bump stop extensions 1", you'll contact the evap canister. So if you jump you JK like Bo and Luke would, then you could pop it. If you plan on testing this, please post the video.
Sounds like fun, some one lend me your keys and grab a camera!
Oh wait you want me to do that in my Jeep? Not gonna happen.
Old Nov 2, 2009 | 12:11 PM
  #63
hansen65's Avatar
Originally Posted by hansen65
Hey guys, has anyone done this mod (either the original way it was posted or using a Kit) that has the EVO lever rear coil over setup? I am thinking of running this suspension setup down the road so I don't want to relocate the evap if its going to be an issue.
So anyone out there that has tried this?
Old Nov 6, 2009 | 04:26 AM
  #64
sin52's Avatar
What's the height of the bumpstops? If they're the same or more than the TF 2.5 BB mine doesn't hit. Does that make sense?
I went to the web page. looking at the pics track bar is in front of axle instead of behind so liiks like it might hit at full stuff. Need pics from front of axle to tell for sure.
Old Nov 9, 2009 | 11:55 AM
  #65
espdjk08's Avatar
I wish i would have read this before I bought my relocation kit from Kilby. Does anyone know if I will have any codes pop up after install.
Old Nov 9, 2009 | 10:48 PM
  #66
fighterpilotmav's Avatar
...... not to sound like a noob or anything but what does the evap do? I understand we relocate it to protect from damage.... but i dont know what it is for...
Old Nov 10, 2009 | 06:21 AM
  #67
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
It collects fuel vapor that would otherwise escape into the atmosphere. Once in a while, a system kicks in that cleans it out and sucks the vapor from the evap can into the intake manifold where it gets burned off in the motor.
Old Nov 27, 2009 | 05:19 AM
  #68
sin52's Avatar
More enviro friendly, nasty vapors.
Old Nov 30, 2009 | 04:43 PM
  #69
dlud51's Avatar
I'm thinking about doing this mod but can someone please tell me what size bolts are needed? Also, can some elaborate on hammering out the bracket so the canister sits level?
Old Dec 1, 2009 | 04:44 AM
  #70
sin52's Avatar
When you go to pick up the new nuts and bolts bring one of the origionals with you. go 1" longer and you'll have no problems. I never hammered anything flat, you won't need to. If there were some reason I wanted to return it to it's factory location I could. Nothing has been modified on the relocate I did. I haven't had any problems.
