ESP Kill Switch Writeup
Old Feb 2, 2013 | 05:58 AM
  #31
olyelr's Avatar
Originally Posted by AtlJeepsTer
The reason the Steering wheel steps are done is because the Steering wheel angle sensor is part of the ESC system and to make sure it is calibrated right and not do it's job , if not for these steps, it could falsely think the wheel is in one direction and other sensors readings and cause you to have a major flip over, maybe during High speeds....That wouldn't be fun...LOL...
To Disable the system, not just Off, 100%:
Disabling ESC For Modified Vehicles (4WD
Models Only)
Vehicles modified with larger tires and/or suspension
lifts may experience early ESC activations as compared to
a non-modified production vehicle depending on lift
size, tire size, suspension changes and/or driving habits.
If early ESC activations are experienced while driving a
modified vehicle, the additional ability to permanently
turn off ESC is available. A steering wheel/ESC button
maneuver must be performed to permanently disable
ESC and defeat the functionality of the ESC switch.
Repeating the procedure will return the system to normal
ESC operation and restore ESC switch functionality allowing
ESC “Partial” or “Off” modes.
With ESC in the permanent disable mode, enhanced
vehicle stability offered by the ESC and ERM systems
is unavailable. In an emergency evasive maneuver,
the ESC and ERM systems will not engage to
assist in maintaining stability. This disabled mode is
intended for off-highway or off-road use only. Vehicle
modifications requiring the owner to configure
the vehicle in the ESC disabled mode, will seriously
affect the vehicle’s roadworthiness and safety and
may lead to loss of control and/or collision resulting
in possible serious or fatal injuries.
The following procedure will disable (or re-enable) ESC
functionality in the vehicle:
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the
wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb
check.
5. Turn and hold the steering wheel one-half turn to the
right (clockwise).
6. Press and hold the ESC OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and
hold an additional one-half turn to the left (counterclockwise).
8. Press and hold the ESC OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESC OFF button for seven seconds.
11. Cycle the ignition key to OFF.
After performing the ESC disable
Yes. I performed this procedure (exactly)... in excess of 30 times... and it never once worked.
Of course it does anytime, when you cut the line and install a switch, you are cutting the Can Bus comunication for all that the ESC consist of
ELECTRONIC BRAKE CONTROL SYSTEM
Your vehicle is equipped with an advanced electronic
brake control system that includes Anti-Lock Brake System
(ABS), Traction Control System (TCS), Brake Assist
System (BAS), Hill Start Assist (HSA), Electronic Roll
Mitigation (ERM), Electronic Stability Control (ESC),
Trailer Sway Control (TSC), and Hill Descent Control
(HDC). All of these systems work together to enhance
vehicle stability and control in various driving conditions,
and are commonly referred to as ESC.
The Switch use to be Labeled ESP which is all of the above as a system and the switch allowed to control just the ESC without effecting other features of the system.
So i would think by disrupting the switch completely will effect more then what some are thinking it does. Be Safe to any and all that have or are doing this Hack.
From what I understand, cutting the wire shuts everything off (as this mod was intended).
Just a decade or less ago, most vehicles didnt even have a system like this. Now thats its out, many people think is completely wrong and dangerous to not use it. People are no longer learning how to drive there own vehicle, they rely on all this traction control stuff to do it for them. I think it is a great setup personally... when driving on the road. But off road, most of this stuff is complete garbage.
Old Feb 2, 2013 | 06:15 AM
  #32
AtlJeepsTer's Avatar
Well we have a Moose and the Government to thank for that too....lol...Law requires it..
The United States Laws requiring ESC for all passenger vehicles under 10,000 pounds (4536 kg), phasing in the regulation starting with 55% of 2009 models (effective 1 September 2008), 75% of 2010 models, 95% of 2011 models, and all 2012 models....
Old Feb 2, 2013 | 10:43 AM
  #33
olyelr's Avatar
For what its worth, i do not drive on the road with the system off. I kinda like it while on the road, especially when my wife is driving in the winter. But, being able to shut it completely off for off road is ideal.
Old Feb 2, 2013 | 12:55 PM
  #34
olyelr's Avatar
Originally Posted by jeeperjkjeeper
Best tool used in this mod was the Molson Canadian bottle....you have good taste eh?
I'm no conuck, but I sure love your beer! The ketchup covered fries are not all that bad either!
Old Jun 3, 2013 | 09:34 AM
  #35
nmoldie's Avatar
This is an old post but, I just found it. Does this work on a '13 JK??
Old Jun 3, 2013 | 10:09 AM
  #36
Nibsirb's Avatar
worked for mine…
ID:	464367Click image for larger version
Old Jun 3, 2013 | 03:55 PM
  #37
nmoldie's Avatar
Originally Posted by Nibsirb
Thanks PM sent.
Old Nov 18, 2013 | 08:32 AM
  #38
Divi's Avatar
id this over the weekend on my 14 JKU rubi worked like a charm, just waiting on the monetary switch to arrive to hook up.
Old Nov 18, 2013 | 08:47 AM
  #39
DeucesALLin's Avatar
Default Fwiw
I did this, as well as a kill switch for the electric fan. Those fans hate mud and water, and if gravel is flying things can get expensive quick. SO throw a 30amp relay in there and make a matching switch for water corssings and mud pits... youll be happy you did.
Also, I know guys talk about the SPAL waterproof fan- but it DOES NOT FLOW LIKE THE OEM UNIT. I use Advanced Auto's Lifetime replacement fan, $130 and another $10 for the switch. However, had I had just put in the switch first I would never have needed the fan.
Old Nov 19, 2013 | 05:48 AM
  #40
ronjenx's Avatar
The purpose of the steering wheel dance was brought up earlier in the thread.
It's my opinion the elaborate moves are required to make it absolutely clear in court the driver wanted it turned off, and it wasn't inadvertently turned off because it was too easy to do so.
It takes some of the heat off the manufacturer when the JK is rolled and it's discovered ESP was off.
I'm really surprised they give the owner the option.
