Grill Mod
Old Apr 1, 2012 | 01:50 PM
  #1111
Strangely Different's Avatar
Did mine today, used a 13gauge 16" x 30" separated steel sheet found at a local Ace HW, lowes and HD had nothing similar. This was thick enough to contour it for the curve of the grill shell. Only had to trim an inch from one end and fitted the bottom around the clips. Now my grill is 10x as rigid
ID:	298227Click image for larger version
ID:	298229Click image for larger version
Old Apr 2, 2012 | 06:30 PM
  #1112
n2v's Avatar
n2v
Originally Posted by DBB888
I ordered mine through www.mcmaster.com
type in sheet metal
Click "Sheet Metal Products:
Click "Sheets,Bars,Strip, Cubes"
Thats for the sheet- 28.5x14
Part # 7582K12 for the zip tie cubes in black
I used Brake cleaner to clean the grill and black caliper paint to paint it.
Paint first so its ready for install!!
I Took out the 6 plastic screw- did by hand - hint hint
Pulled gently by the blinker- not to hard now its still connected
Pulled red tab out FIRST- then pulled plug out
Pulled bottom out
Have grill ready
Laid all the tie downs - 3 going down and one on each top hole
Zip tied each one using a small screwdriver to help get the tie up
Re Install the grill and Vuala!!
THANKS Ponpeta!!!!!!
thank for the site- looks pretty awsome- and can customize my choice of grill pattern -
this is my first post - and venture to modding my 2011 - tan -dual black roof sahara!!
it came with factory rims- silver , blah:( and of course the silver front and rear center bumper trim- needs to go!!
gonna change to black rims - but think this project is a great start to tinkering with my new toy- its actually used for work , and i freakin love it
thanks for keeping sum change in my pocket and the great ideas!!
n2v
Old Apr 2, 2012 | 06:51 PM
  #1113
Matthewd5's Avatar
n2v
great post!
where you have the screws i have the round plugs where you need to either pry them out with a flat head screwdriver and they get mushed, or if you use a chip extractor they are reuseable
i have a 2012 2 door sport s
matthew
Old Apr 2, 2012 | 07:24 PM
  #1114
Matthewd5's Avatar
Originally Posted by RedRubicon11
Did this mod yesterday with the gutter guard and I used spay on bed liner to paint it. It looks good and was super easy to do. I cant believe I waited so long to do this.
what bed liner did you use??
i used the dura liner spray and it comes out really lumpy and uneven
matthew
Old Apr 2, 2012 | 07:31 PM
  #1115
Wolf_425's Avatar
matthew
I used the rustoleum Bed liner when I did mine. Came out with a nice textured finish.
Old Apr 14, 2012 | 04:27 PM
  #1116
beachmoney's Avatar
Default Looks Great!!!
ID:	304020Click image for larger version
ID:	304021Click image for larger version
I used plastic gutter guard that i got at lowes for 3 bucks and it worked out great!
Old Apr 14, 2012 | 04:33 PM
  #1117
afpilot82's Avatar
JK-Forum Ambassador
Knocked this mod out today.
Old Apr 14, 2012 | 05:08 PM
  #1118
Jdell68's Avatar
Did mine last month with the aluminum sheet from HD. used the tie down squares, tie straps with contact cement so far holding on strong...
ID:	304043 Click image for larger version
Old Apr 14, 2012 | 06:24 PM
  #1119
robsjeep9's Avatar
JK-Forum Ambassador
First built a workbench to do my grille mod...
tedious work but love the result!!
I actually used a dremel with a sand paper attachment to remove all the sticky pads off the zip tie blocks soooooo much faster. Also used goop contact cement glue for PVC,plastics etc on the back and for an extra security used gorilla glue on top of the blocks(that's why it looks messy) no one sees that side anyways. Painted yellow of course go Steelers!!
Sorry Iphone I downloaded the pics in proper sequence BUT it obviously didn't turn out that way lol
ID:	304117   Click image for larger version
ID:	304126   Click image for larger version
ID:	304127   Click image for larger version
ID:	304128   Click image for larger version
ID:	304130   Click image for larger version
ID:	304131   Click image for larger version
ID:	304132   Click image for larger version
Old Apr 14, 2012 | 06:34 PM
  #1120
Matthewd5's Avatar
Is dremeling the zip tie squares a must do?
Matthew
