Marker light mod
Old Jun 7, 2011 | 05:50 PM
  #301
coolhand383's Avatar
Originally Posted by zeppo
It's unlikely that the hardware on both sides has failed but it is possible. I would lean toward the bulbs. I honestly don't know the specifics on the installation of the bulbs as I have never removed mine.
i guess i will try some more new bulbs then? ... thanks man.
Old Jun 7, 2011 | 05:54 PM
  #302
oh one more thing ... i did disconnect the battery when i did the mod. it was disconnected for the duration of the mod (20 mins or so). would this have anything to do with the marker lights not working at all?
  #303
WilKJ's Avatar
Vet Army
Is this still an issue for 2011 models?
This is one of the first things I did and it should be done on all JK.
  #304
zeppo's Avatar
Good luck with the troubleshoot. You'll love it when you get it all working.
Old Jun 7, 2011 | 06:23 PM
  #305
zeppo's Avatar
As far as I know disconnecting your battery should have no effect on the functionality of the lights once it's reconnected. I would also have to say that it's unlikely to get two brand new bad bulbs. When you used the voltmeter to check for power you did it at the connection that goes to the fixture and not the fixture terminals for the bulbs correct? If you can get the voltmeter leads into the fixture I would check there as well instead of assuming bad bulbs. Just check at every reasonable connection point until you find where the break in continuity is.
Old Jun 7, 2011 | 08:48 PM
  #306
Shankspony's Avatar
Doublecheck that you've spliced the black marker wire into the OUTSIDE striped turn signal wire. I'm thinking that you should get a fast blinking replay if you do it wrong.
Old Jun 8, 2011 | 08:24 AM
  #307
yea, definitely got the black wire from the side marker light into the striped wire farthest from the black wire on the front light. i get nothing from the side marker lights. when sticking a voltage tester (just one with the light) into the bulb housing at the wire connection side, the bulb will light up.
Old Jun 8, 2011 | 11:47 AM
  #308
this is so frustrating man. all my other lights work as they should. what is going on?
Old Jun 8, 2011 | 01:23 PM
  #309
mabar's Avatar
Originally Posted by coolhand383
ok, did this mod earlier this evening. followed all the directions. my mod looks exactly like the pics, but my side marker lights don't do anything (come on as running lights or blink as turn signals). i cut the black wire from the side marker light and spliced it into the blinker wire from the front running light. taped off the other end of the black wire. i even replaced the side marker bulbs (good thing cuz they were blown). using a voltage tester i went to each side of the connector at the side marker, and it lights up when the running lights are on and blinks when the turn signal is on. all my other lights work fine and everything about the jeep is as it was before the mod. does anyone have any idea why this would not be working?
I have the same problem. 2011 JK Wrangler Rubicon. Tried to do this mod a couple of days ago.
1. Cut the black wire going to the side marker light.
2. Connected the black side marker wire (going to the side-marker light) to the outer-most white wire of the front parking/turn signal light.
Then nothing on the side marker light. No side-marker light. No side marker turn signal. Nothing.
I double checked my connections, and re-spliced just to make sure I did it correctly. Still no light on the side marker.
Sheeze!
Light bulbs are good. I got frustrated, and re-connected the wires as came from the factory, and all is good now, but NO blinking side-marker mod.
Did something change on the 2011 models?
Mabar
Old Jun 8, 2011 | 01:27 PM
  #310
210GoldenEagle's Avatar
Did this today on my '09. I'm not sure if anything has changed. my mom won't let me try it on her 2011
