Marker light mod
Old Oct 25, 2012 | 07:28 AM
  #521
19Delta's Avatar
Originally Posted by RubiWood
Never hurts to do a write up. I am curious to to see where the LED lights are located. Can you show any pics of those in the daylight.
Here's are some daylight pics.
http://db.tt/E605ucaD
http://db.tt/TXQhsv5Q
http://db.tt/u8ZbDacX
I used 10K WHITE/AMBER TYPE 2 SIDE FIRING LED STRIP LIGHT 54 LED 22 INCH to make mine. They were a tad long, but no biggie, cause you can cut them off.
Old Oct 25, 2012 | 07:32 AM
  #522
19Delta's Avatar
I will try and do a write up. Meanwhile, if anybody orders these, make sure and get "side fire" or edge leds. They are same thing. I saw this on a jeep on the forum here.... can't remember who though. They used red ones though.
Old Oct 25, 2012 | 08:47 AM
  #523
codys11's Avatar
Where did you buy them at? I might be doing to blinker mod this weekend or next.
Old Oct 28, 2012 | 09:09 AM
  #524
Pontiacman's Avatar
I agree. Looks great. Where's the write up? ;-)
Old Nov 22, 2012 | 11:34 AM
  #525
mr.wolf's Avatar
Originally Posted by rah
Did this mod this weekend with my LED side markers. I used a wwrite-up from another forum using 2 diodes and a resister from radio shack. Worked great!
Attachment 316820
rectifier diodes, part # IN4004
560ohm resistors
This worked on my bushwackers. Thanks for posting it...
Old Dec 2, 2012 | 11:33 AM
  #526
Rico's Avatar
Fail!!!! Just tried to do this mod and ...did not work! I have a 12 and 1st I used the pinch clips ...nothing ...then I took them off and wired directly and still Nothing. Then I got a message in the dash saying that the blinker was out. Undid everything and reconnected them and all went back to normal no message.
I can not for the life of me understand why it did not work. snipped the black from side marker and attached it to the blinker far white ...in my case one side had a brown stripe and the passenger side had a red stripe. Did not work............
Old Dec 2, 2012 | 12:03 PM
  #527
Rico's Avatar
K just read through again and it seems I Cut marker black wire...and tried to t wrap the other side of the black wire from loom coming from engine not the black coming from marker........I thought you just snipped the marker and left the black end at the marker wrapped ...I did not think that was the wire being used to splice into front signal wire. Der .........So I will go back out tomorrow and retry. Dark now would not be able to see anything even if I wanted.
Old Dec 5, 2012 | 12:16 PM
  #528
Rico's Avatar
K success I am now in the blinking marker club! I had assumed that the black coming from loom would attach to signal ...when instead it was the black from marker that attaches to signal ...DUH!!! at least It is working now. I was paranoid about people not seeing my blinker ..since reading all of this.
Old Dec 5, 2012 | 01:25 PM
  #529
FireFreak_'s Avatar
Did mine! Works great, thanks for the write-up
Old Dec 9, 2012 | 08:19 AM
  #530
Angryislander's Avatar
Does anyone else's fast flash?
