Superchips Flashpaq for JK, Initial Impressions
Old Mar 23, 2010 | 06:03 AM
  #1331
JKsJK's Avatar
Originally Posted by Abesonite
Mine will be showing up today. A little concerned about the lurchiness bec I have a 6 speed. But will post my results once installed. Any recommendations on settings?
i always come back to the 87 tune. you'll have to play around with your tire setting to get the speedo right. measure actual tire size as best as possible and then tweak as needed. i ran the crawl tune while wheeling a couple weeks ago and i highly recommend. very smooth crawling for my set-up, much more so than with the 87 tune.
interested on your perspective on the lurchiness. it's clearly more responsive than stock, but it's never bothered me nor does it seem an item for concern.
Old Mar 23, 2010 | 06:05 AM
  #1332
GoodysGotaCuda's Avatar
Originally Posted by Gren4deJK
It's really not that bad if you work the clutch a bit. Still a really good investment despite the fact, you'll enjoy it!
as mentioned, use 2nd gear when rolling slow. Works for me.
Old Mar 23, 2010 | 07:08 AM
  #1333
sc0tt's Avatar
When you guys say 87 tune is the the 87 quick tune of the 87 performance tune?
Old Mar 23, 2010 | 07:17 AM
  #1334
ogjk's Avatar
Default Programmed it last week
I went skiing over the weekend and what a difference in the hills and on the highway. There is a little more power I guess, but its like having a whole new transmission. Shifts were sooooo much better.
Old Mar 23, 2010 | 07:21 AM
  #1335
mattman8706's Avatar
I am on vacation right now and only have a mac
anyone know if I can run the program on the flashpaq without plugging it into a pc?
I am tired of my lag and want a little more power.
Old Mar 23, 2010 | 07:22 AM
  #1336
JKsJK's Avatar
i didn't know there was a difference in the tune itself, but i'll have to check again. i believe they are the same tune, with the difference being the quick tune option is to tune only, whereas the other option let's you go through the other things - tire and gear settings, etc.
Old Mar 23, 2010 | 07:25 AM
  #1337
JKsJK's Avatar
there is some info buried deep in the bowels of this thread. someone with a mac will probably post up, but if you need immediate assistance you can probably search through here. or you might try contacting superchips directly to see if they have guidance.
Old Mar 23, 2010 | 07:35 AM
  #1338
batherton87's Avatar
Default Nice
Very good review I'm looking to get a setup like this is the near future
Old Mar 23, 2010 | 08:06 AM
  #1339
I just talked to them directly
Old Mar 23, 2010 | 10:10 AM
  #1340
Adam3612's Avatar
adam - do you have pinging now with 87 or just being cautious? the only time i have ever noticed pinging with the superchips, on any tune, is when i first installed and the install clearly didn't take properly (i.e., my speedo didn't register, etc.).
Right now im at stock settings because the lurchy throttle issue was driving me nuts, job takes me all over the city and sometimes I find myself in bumper to bumper traffic at quitting time, thats when it got so bad I set it back to stock. I had no issues with the pinging but Goody did while using the 87 tune and he remedied that by using 89 octane fuel with the 87 tune, so yeah basically just me being cautious.
Originally Posted by GoodysGotaCuda
That I haven't noticed. I'm driving the Jeep again today and will see. Probably no change at low speeds. But my pinging is certainly gone, my torque is noticeably better with the 89 octane on 87 tune.
Will let you know. My 'shutter' is also gone when changing to relatively high gears at low speeds.
The shutter/gettingrearendedsimulator was even bad when I used 2nd gear instead of first and im 100% certain the tune installed properly and the programmer had the most recent updates. I think I might update, reinstall the tune and fill up with 89 once this tank runs out. Hopefully they find a fix to make the throttle issue go away tho.
