Superchips Flashpaq for JK, Initial Impressions
Old Apr 14, 2012 | 06:13 AM
  #2331
demtek9's Avatar
Originally Posted by jkfisher84
OK so here's a noob question! I recently purchased a lift and still deciding on wheels and tires but if I went with 35s and a flashpak with 3.73 gears on a jku would I still need to turn off the OD?
I dunno, but try without turning OD off and see what you get.
This was the first mod I got besides a front bumper and love it.
Old Apr 14, 2012 | 06:22 AM
  #2332
JPop's Avatar
With speeds above 60mph it will still be advisable to turn OD off for better efficiency.
Old Apr 14, 2012 | 06:58 AM
  #2333
jkfisher84's Avatar
Thanks! Anything else I should know of before I pull the trigger on some tires? Pros and cons, anything associated with the flashpak, etc. etc. ?
Old Apr 14, 2012 | 07:06 AM
  #2334
pcmasten's Avatar
Veteran: Marine Corp
you'll have to play around with the tire size in flashpac to get your speedometer set correctly. I have mine set for 33 1/4 for my Falkens.
Old Apr 14, 2012 | 07:09 AM
  #2335
jkfisher84's Avatar
What's that size from, a 285 size? I've been trying to find around a 34" size, a compromise between 33s and 35s.
Old Apr 14, 2012 | 08:18 AM
  #2336
09BlackRubiNC's Avatar
I just put the gps in the window and cruise down the road and compare the speedo and gps. Come home and recal if necessary and run out again. I think I'm set at 33.25 for 35" tires.
Old Apr 14, 2012 | 08:20 AM
  #2337
pcmasten's Avatar
I'm running 315/70R 17 Falken Rocky Mountains.
Old Apr 14, 2012 | 08:31 AM
  #2338
jkfisher84's Avatar
U have 315s and they measure out to that! Are they heavy?
Old Apr 14, 2012 | 08:58 AM
  #2339
JPop's Avatar
Measured tire sizes are going to vary with wheel width and inflation rate. For every inch narrower of wheel width you run you'll pick up around a quarter inch in diameter. Wider wheels will decrease diameter at about the same rate.
Old Apr 14, 2012 | 09:02 AM
  #2340
jkfisher84's Avatar
Interesting, makes sense!
