Old Mar 17, 2018 | 12:25 AM
  #6261
Mark Doiron's Avatar
Originally Posted by Clark Collins
My wife and I just returned from a two month trip to escape the cold weather here in Idaho. ...
Looks like a great trip; thanks for sharing!
Old Mar 19, 2018 | 07:16 AM
  #6262
NMBruce's Avatar
I no longer own a Jeep, but all of you keep me coming back with your great trips and build ideas. Thanks
Old Mar 22, 2018 | 06:33 PM
  #6263
Cascade Wanderer's Avatar
Veteran: Marine Corp
Suggestions for quality aftermarket non-LED headlights for a JK that sees considerable use in adverse weather and in the mountains?
Thanks, Guy
Old Mar 22, 2018 | 11:30 PM
  #6264
Thanks, Guy
If you want lights that perform pretty much as OEM lights do on most vehicles (the JK being a notable exception), then I recommend the IPF headlights. If you want more light than typical OEM, then the IPFs likely won't satisfy.
Old Mar 24, 2018 | 10:59 AM
  #6265
Thanks Mark, I like the way you put that, and yes, the IPF's will probably satisfy. I've got a pair of small Vision X lights that I can run as amber fogs, or as more of a general purpose driving light if I need more than that.
And, plenty of room on for a set of some kinda LED Laser-Blasting off-road only type lights if I want them. Normally though, no need. When it's dark, I'm usually hanging out by the campfire, not driving.
Guy
Old Apr 9, 2018 | 10:31 PM
  #6266
Short video teaser of my most recent trip ...
Old Apr 12, 2018 | 02:51 PM
  #6267
Wandering the Southwest, well, Utah and Arizona anyway. These photos all from Utah within the past week:
On the Nine Mile Canyon drive:
White Rim Road:
Very pleased with how well the Jackwagon trailer tracks, both on and off pavement. I've used it a bit in Washington, but this is the longest trip I've used it on, about 1500 miles so far.
Regards, Guy
Old Apr 12, 2018 | 07:51 PM
  #6268
Old Apr 20, 2018 | 10:07 AM
  #6269
JKMM2011's Avatar
https://www.youtube.com/watch?v=zFI8ugEYb6Y
Watching you new series and hope to hear the answer to your overheating issues. Again great photography and enjoy your trips looks like you all are having a good time..
Old Apr 22, 2018 | 02:13 AM
  #6270
The series is now complete and online. Here's the first one ...
As for the overheating, let me just say I made the trip okay. And on my workbench I have the suspect part to replace. It's the relay I use for turning off the engine cooling fan when crossing deep water. Pretty sure that vibration has taken its toll on the contacts, causing it to on occasion have high resistance to the engine fan input voltage. The video series does not go into every instance of the problem. It first started, after seven months of thinking I had it fixed, while in Guymon, OK. They have cobblestone streets that were vibrating the heck out of the Jeep. And every time after that it was on some type of high vibration surface--such as a washboard road. Some moderate tapping on the relay would allow the fan to work again. It's also possible that the wiring at the relay is loose, so I'll be checking that over closely when I replace the relay. Beyond that, well, I'll let you watch the video series to see exactly what happens and when and how I was prepared to handle it. ;-)
