Side-mount Jerry Can Carriers for the JK
Old Mar 7, 2016 | 03:34 PM
  #151
jscherb's Avatar
Originally Posted by jeepmojo
I forgot what size bolts those were but something like this maybe ?
JSCHERB : DO YOU RECALL THREAD SIZE ?
Mine stays on full time 24/7 i like the look of it there even if its not full
The bolts that hold the tray to the mount are 5/16-18. A flathead screw like you pictured would not be a good choice - a better choice would be a truss head screw, they have a very low profile head that tightens against a flat surface, so if you were going to replace the bolts that come with the kit with anything you might want to try truss head.
The neoprene sheet does do a good job of preventing movement of the can, so make sure you've got that in the tray as well - I haven't heard of any issues with the supplied hardware or can movement/noise issues from anyone else, and in the many miles I've run with mine I've had no issues with can movement or noise.
Old Mar 7, 2016 | 08:29 PM
  #152
jeepmojo's Avatar
Default no me either mines so far seems secure
but might just replace them with truss head as you mention as a preventive measure . but i have not noticed and noise highway or over bumps . i havent pulled the can off to see though it its been rubbing . I will though just to see today.
some gorrila ttape on can would temp, it in the mean time while lookin for truss head 5 /16 x 1 x 18s thanks im not anal over it if theres scratch but dont want it to wear or rust out so better safe than sorry
Phillips Truss Head Machine Screw 18-8 SS - 5/16"-18 x 1" Qty-1
$0.53 so about $1.00 @hardware store stainless steel
Old Mar 8, 2016 | 08:34 PM
  #153
Erok's Avatar
There should be a 6x12 piece of neoprene foam included with the side mount kits - the foam goes in the bottom of the tray, and prevents the can from slipping around in the tray - did the foam sheet not come with your kit?
The foam works for most daily driving.. but on the very bumpy washboard trails in Big Bend it wasn't enough. The can is able to shift at its base and bump the bolts.
Flush bolt heads like this would probably fix it! I'm still thinking of just adding a second pair of bump stops near the bottom so the can isn't able to move at all.
Old Mar 8, 2016 | 08:36 PM
  #154
Erok's Avatar
Anyway jscherb, it's a minor issue. I'm still really happy with the setup, you know there's just always something to tweak.
Old Mar 8, 2016 | 08:39 PM
  #155
Erok's Avatar
I took a lot of care with the neoprene, and I really tighten down pretty hard on the strap so the can won't move. It may just be the amount of vibration it got subjected to.
Old Mar 9, 2016 | 08:06 AM
  #156
DJ1's Avatar
DJ1
Former Member
Get away from the metal cans, go Scepter military spec cans, and be done with it. No rattles, no paint to chip, no metal to rust out, and the construction is bomb proof. You can run over them and the seams still won't break. That's because they're seamless! Might actually work as a "cushion" when you bang up against trees on the trail.
Get the cap wrench for it to tighten it down and the regular walk-by thief won't have a chance getting the cap off to steal/siphon off your go juice.
Glad I bought mine 4-5 years ago because the prices today on flea-bay have definitely gotten up there....
Old Mar 9, 2016 | 08:41 AM
  #157
jeepmojo's Avatar
Default i checked mine yesterday very close
those bolts are 1/4 inch away from touching the can (all 4)
but bupstops on upper prevent a contact So i can see this issue of vibration or movement of jerry Can being a problem tooat bottom of can in the future. I
think the replacement bolt is the answer for me on this over adding more gizmos to bumpstop , but again will have to be stainless steel bolts replacements & will be additional expense to the consumer. Not a big issue @this point but as you mention a (tweak) that is required to prevent rubbing most likely
Thanks for the forewarning its just these comments that can prevent the future repair work on the buyers behalf.
on the scepter can , resolving the matter, im not so sure the same issue couldnt cause chaffing to the plastic and result in gas leak over time if there was any movement or vibration as mentioned by( Erok) & I personally dont care for the looks of the scepter cans, for mine, but they may be stronger im not sure . my wavian cans are stout . & have to agree out of control on price for a gas can these days.
DJ1 have you received your holders yet? you might want to just buy flat head bolts a head of time rather than having to do it later. 5/16x 1"-18 stainless steel
Old Mar 9, 2016 | 11:47 AM
  #158
Cascade Wanderer's Avatar
Veteran: Marine Corp
Install was smooth and simple an hour ago. The two-door now has more range!
Old Mar 9, 2016 | 12:05 PM
  #159
jscherb's Avatar
Congrats! Looks great, the black cans are a nice choice for the white Jeep.
Old Mar 9, 2016 | 12:12 PM
  #160
DJ1's Avatar
DJ1
Former Member
3 of my 6 fuel scepters are all scratched/chaffed up so that's not too much of a concern but I can always superglue or screw in some rubber pads if I think it'll be an issue. I doubt it though.
Don't get me wrong, the old-school cans are nice but I can't see them holding up under tests like these:
http://expeditionportal.com/equipmen...cepter_can.php
...and this is just the Scepter water jug!
Name:	Screen Shot 2016-03-09 at 1.10.18 PM.png
Scepter was founded in 1949, and developed “Scepterene” a resin that is impervious to gasoline and began making fuel cans in the sixties. In the mid 80’s, Scepter designed a three handled polyethylene fuel can derived from the original 20 Liter"Jerry-Can" designed by the German army during WWII for use in the blitzkrieg of Europe. This can proved itself to be a vast improvement over the previous metal cans. These new cans were tested, and were quickly accepted as the new fuel can standard for Canadian Military Forces converting previous requirements from metal to plastic cans. In the 1990s, the US Military, also tested and adopted the Scepter fuel can as their new standard.
In military live fire tests, these fuel cans were shown to melt and burn without exploding, making them significantly safer than their metal counterparts. They exceed United Nations Transportation of Dangerous Goods Model Regulations. Scepter's MFC cans are built to exacting U.S. Military specifications (MIL-spec). Rugged in design, Scepter’s MFC’s are built using high molecular weight, high density polyethylene featuring seamless all-plastic construction.
Still awaiting arrival of both units. Thanks for the heads up on the bolts.
