Superchips Flashpaq for JK, Initial Impressions
Old Oct 18, 2010 | 04:17 PM
  #1761
old3's Avatar
I just downloaded my 87 octane tune at sea level and can tell you, I wouldn't have needed to put a turbo muffler to hear my RPMs to avoid stalling all the time if I had this first. The pedal response is perfect, the power starts at 1200 RPM if I step off the clutch in first with no gas and floor it after its walking away!
Love it. 4.88s, 32s, 6m trans. It actually feels quick now, gears did about 80% IMO, tune polished it up nicely. NO complaints, shoulda been delivered this way. Can't tell its a drive by wire now. Perfect.
Old Oct 19, 2010 | 05:58 PM
  #1762
tcodtj's Avatar
I returned mine to the stock setting before going to the dealer for the hot oil recall. I had a 30 mile drive back home before I reprogrammed and I think that the jeep had more power with the new flash from the dealer than before with the 87 tune. I then updated the fpaq and reinstalled. It seems to me that it has more balls than ever.May just be in my head but I don't think so. I can almost tolerate it now, not really, pos v6.
Old Oct 22, 2010 | 06:26 AM
  #1763
membrain's Avatar
Originally Posted by Scott@Superchips
The tuner must be vin locked to your vehicle in order to see the Trans tuning feature and TPMS offroad.
Advanced trans tuning is located under vehicle one in the drop down menu at the top of the Internet Update page.
PM me if you need assistance.
Scott
I have 2 JKs, 1 automatic and 1 manual...
If I purchase a Superchips Flashpaq and VIN lock it to the automatic will I still be able to use it on my manual to adjust/modify all the original non-VIN locked parameters?
Old Oct 22, 2010 | 06:44 AM
  #1764
Scott@Superchips's Avatar
Sponsoring Manufacturer
Superchips Representative
Unfortunately no, there is not enough memory in the product to handle two vin's due to the fact that Chrysler/Dodge/Jeep files are enormous in size. You would have to return the primary vehicle to stock to tune the second.
Scott
Old Oct 22, 2010 | 06:52 AM
  #1765
membrain's Avatar
Scott
thanks, and to clarify, only one vehicle even without the vin lock.
Old Oct 22, 2010 | 07:10 AM
  #1766
jdubb75's Avatar
When you plug the programmer into a vehicle and tune it, it automatically locks to the Jeeps VIN until returned to the stock settings.
Old Oct 22, 2010 | 07:17 AM
  #1767
many reach the 2.5meg mark.
Scott
Originally Posted by Scooter Scott
How enormous are these files?
Old Oct 22, 2010 | 11:18 AM
  #1768
JaxLoki's Avatar
Default Speedo fix
Without flipping thru all 184 pages of this thread... Have ya'll had trouble setting the tire size to get the speedo to read correctly. I have set it to 35" for my 35" tires, but it way off. If I set it to 31.75" then it is just about right on the money... Anyone else experience this?
Old Oct 22, 2010 | 11:27 AM
  #1769
jdubb75's Avatar
Did you read through the intruction manual that came with the Flashpaq? You have to measure the diameter of your tires and enter that number instead of using the numbers on the sidewall...they are rarely ever correct.
Old Oct 22, 2010 | 11:35 AM
  #1770
mpkelley20's Avatar
I had same issue. Proper measuring did NOT get me the correct speedo calibration. I had to use a lower size for the programmer than what my tires measure (and I used every possible method of measuring them!) I am at about 0.5" less than what my tires measure using the various methods I tried. Speedo is still not perfect but its only off about 1-2mph now at 65 which is pretty much normal differences anyway.
