Superchips Flashpaq for JK, Initial Impressions
Old Oct 5, 2010 | 12:54 PM
  #1741
rinkishJK's Avatar
yes. think of u installing a new tune just like disconnecting the batt to clear it. same thing. thats why it says no bus and guages go hay wire.
BTW ur jk looks sick pluke!
Old Oct 5, 2010 | 01:09 PM
  #1742
jacktomsic's Avatar
Default Octane???
A newbie, please be gentle with me. In looking at performance chips and the various settings for 87, 91, 93 octane fuels does it take into consideration the decreased requirement for higher octane with high altitudes, i.e, above 6-7000 ft. msl. Here in Colorado, you can not get 93 octane easily. Being in the oil business most of my life, it is common knowledge that you decrease the need for high octane with the decrease in available O2. Thus only 85, 87, 91 is offered in high altitude markets.
Old Oct 5, 2010 | 01:24 PM
  #1743
Pluke the 2's Avatar
Thanks bud. Looks like yours is the upgraded version of mine, 5k later, and 5 years
Old Oct 5, 2010 | 04:08 PM
  #1744
jdubb75's Avatar
Okay, so I loaded the 87 tune tonight. I love it! Yes, I've got some pinging, but I've only put about 16 miles on it. I flogged it pretty good for the first 10 miles or so...taking off with a heavy foot, making it downshift around 35-40 and letting it wind out pretty good. I can tell some of the pinging has already started to go away so well will see what happens over time. I can also tell the trans has a much firmer shift under heavy acceleration. Throttle response off the line is 100% better. All in all, I'm a happy camper right now.
I'm running 35" KM2's that measure just a hair under 34" using a level across the tread and measuring to the floor and I set the tire size to 33.75". I checked the speedo with a gps and it appears to be spot on.
I'm going to play with the other functions as time allows.
Old Oct 7, 2010 | 06:33 AM
  #1745
Default 2 Days Later
Superchips Update W/ 87 Octane, 2 Day's of Owning it, Less than 50 Miles.
NOTE: Overdrive on is when you put your key in the ignition and you just drive.
NOTE: Overdrive off, is when you put your key in the ignition and you manually press a button that is below the air-conditioner controls which toggles "O/D Off"
Not even to 50 Miles on my SuperChips yet.
Before my superchips with the overdrive off (Auto)
I would be on the freeway, speedometer telling me 70 MPH but GPS telling me 82 MPH , and I would be at 2800 - 3,000 RPMS (OVERDRIVE OFF).
With the Overdrive left ON, I would be at 2,000 - 2,200 RPMS @ 70 MPH but GPS telling me i'm going 82 MPH.
UPDATE WITH SUPERCHIPS:
OVERDRIVE OFF W/ SUPERCHIPS
I corrected my speedometer, so I am now going a real 70 MPH per the GPS and the dash, with the overdrive OFF, I am at 2400-2600 RPMS almost perfect.
Overdrive on w/ Superchips
Going 70 MPH with the Overdrive ON and superchips, my RPMS are at 1400-1600 but it holds small inclines a little better, meaning it has a little acceleration before shifting in gears.
To soon to tell any real comparisons. of course the girlfriend say's "OMG, IT'S A HUGE DIFFERENCE"
will report back.
Old Oct 7, 2010 | 06:44 AM
  #1746
JPop's Avatar
When the girlfriend or wife notices a difference, I think you are on to something.
Old Oct 7, 2010 | 09:26 AM
  #1747
stefel22's Avatar
just curious just did an update and didnt see the transmission package , can anyone chime in on this . Guess Ill browse the superchip website
Old Oct 7, 2010 | 09:39 AM
  #1748
jdubb75's Avatar
I just bought one a couple days ago and didn't see it available for download either. I haven't had a chance to play with the Flashpaq other than loading the 87 tune and setting the tire diameter. If you find anything out, post up.
Old Oct 7, 2010 | 12:09 PM
  #1749
Scott@Superchips's Avatar
Sponsoring Manufacturer
Superchips Representative
The tuner must be vin locked to your vehicle in order to see the Trans tuning feature and TPMS offroad.
Advanced trans tuning is located under vehicle one in the drop down menu at the top of the Internet Update page.
PM me if you need assistance.
Scott
Old Oct 7, 2010 | 06:41 PM
  #1750
CamTom12's Avatar
Originally Posted by mediocre69
Measure your tires first so you can enter it into the flashpaq. Use a level across the top of the tire and measure to the ground for the best measurement. Then set the tire height and try the 87 octane tune.
I'm about halfway through this thread but I used to tune LS1's and LS2's. The best way I've found for accurately measuring tire diameter for tuning is to measure from the ground to the center of the hub and multiply by 2. This shows the computer the diameter it'll see as the weight of the vehicle is compressing the bottom of the tire.
I'm sure it's pretty close the other way though.
