Superchips Flashpaq for JK, Initial Impressions
Old Feb 28, 2012 | 07:14 PM
  #2281
JPop's Avatar
Originally Posted by IcyFridge
So you're running regular fuel on your 91 tune or running that on the 87 tune?
I always run the designated octane or higher than what the tune calls for. If you run lower than the tune, it starts hitting the knock sensors and backing out the timing anyway.
Old Feb 28, 2012 | 07:17 PM
  #2282
JPop's Avatar
Originally Posted by jeepcop31
So if I'm staying with the 33's, are the 3.73's and the programmer okay or would I benefit greatly from 4.88's and a programmer?
You should roll with it for a while and see how you feel about the performance. If it's gear hunting or having frequent downshifts you should start investigating what gears make the most sense.
Old Feb 28, 2012 | 09:27 PM
  #2283
It doesn't shift too much so I think I'll go with the uncorking and flashpaq for starters. Hopefully that will show some mpg gain and then I'll regear when I switch to 35's. Here's the bottom line. I have about $1500 to spend and my main goal is to gain some mpg. I'm really looking for advice on the best way to spend my $$$.
Old Feb 29, 2012 | 06:51 AM
  #2284
memedya's Avatar
I just installed an 87 tune this morning (still have a full tank of it). I maybe reading it wrong, but do you suggest to run 89 with 87 tune?
Or were just pointing out the importance of not going lower?
Old Feb 29, 2012 | 07:49 AM
  #2285
JPop's Avatar
Originally Posted by ismai1
was gonna get one of these today at the 4x4 shop while getting my new 33's. the owner said not to even waste my money and that they dont do very much of anything. he said it's cheaper just to go to the dealer to get them to recalibrate the computer for larger tires as it's only 80$ to do it there opposed to 300$ for the superchip. he said they're pretty much useless on gas engineshe's the owner and I would assume he'd want to make a sale so I trusted he was being honest.
Obviously this shop owner has no practical experience with this product. There are some other products out there that don't do much of anything, but certainly not a Flashpaq or Vivid. I'm also surprised that they wouldn't at minimum recommend a Procal as you can do your tire calibration yourself for not a whole lot more than what he stated the dealer would charge. Lastly, the dealer cannot calibrate for tires larger than 32" and gears above 4.10s.
Old Feb 29, 2012 | 07:51 AM
  #2286
JPop's Avatar
The important thing is not going lower than the Tune. For instance you don't want to run the 91 tune on 87 Octane fuel.
Old Feb 29, 2012 | 08:05 AM
  #2287
memedya's Avatar
Wasn't 100% sure. Thank you.
What do you think of running 87 tune while using 89 gas?
Old Feb 29, 2012 | 08:21 AM
  #2288
JPop's Avatar
It certainly wouldn't hurt anything but there wouldn't be much benefit. As infrequently as you'd bump up against the knock sensors using the prescribed octane, you run into them even less with a bump in octane. If you have changed some sort of mechanicals such as a throttle body (not just a spacer) or added headers there could be a benefit as well.
Old Feb 29, 2012 | 08:42 AM
  #2289
memedya's Avatar
Let me pick your brains just a tad more.
I have K&N drop-in filter and Flowmaster muffler, but this morning just ran 87 tune for stock engine (3.8)
Should I bother with Advanced tune or add-ons that I have aren't significant enough?
Old Feb 29, 2012 | 09:00 AM
  #2290
JPop's Avatar
Neither of those items will change things dramatically enough to effect the tunes. Headers can as they cause better cylinder evacuation and a throttle body will let more air in at lower throttle position percentages without having the tables changed to accommodate the larger bore.
